98 Camry I4 stops running in stop & go traffic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2007, 05:36 AM   #1 (permalink)
WAB
Impeller Terrorist
WAB's Avatar
View WAB's Photo Gallery
My 98 Camry I4 with 145,000 miles runs great normally, but it has recently started shutting off in stop and go traffic. When it does this, the engine temp appears in normal range. When it shuts off, it won't start again for 10 to 15 minutes, and then runs rough and bucks until you can get to reasonable speed, and then runs fine again. Timing belt, plugs, plug wires, and both coils were just replaced, but the problem persists. Any suggestions.....please!
Tercels teach patience
WAB is offline   Reply With Quote
Old 04-07-2007, 02:57 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
how low is your idle?
HaHa
Old 04-07-2007, 03:11 PM   #3 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
if you wait 10 or 15 minutes for engine to cool down, sound like ECT sensor malfuction, telling ECU the engine is still cold, and give more gas, thus, flooding the engine with gas at low idle, but just my guess, i could be wrong.
bronzemaxell is offline   Reply With Quote
Old 04-07-2007, 03:24 PM   #4 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
haha, sounds like my friend's old manual trans. mustang before he worked on it...
dont let any repair shops throw parts at it until you figure out exactly what the problem is
honestly, this could occur due to so many things that you can end up spending a fortune if you dont do your research first
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 04-07-2007, 04:03 PM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
in addition to those suggestions above, have you checked or ever replaced your pcv valve?
cheap part and very easy to check if it's still good on your i4 motor.
nodrogkam is offline   Reply With Quote
Old 04-07-2007, 07:11 PM   #6 (permalink)
WAB
Impeller Terrorist
WAB's Avatar
Thanks for the advice
Thanks, guys. I have not changed the PCV valve, so I will try that first. If that doesn't work, I will try those other ideas. You are right on about throwing parts at the problem. So far I am at about $600, and the same problem persists. I will let you know how it comes out, and if anyone has any other ideas, please let me know.
Old 04-07-2007, 07:30 PM   #7 (permalink)
nodrogkam's Avatar
oh i guess the other problem could be a really gunked up throttle body and idle air controller that can be cleaned out with liberal usage of throttle body cleaner.
for the pcv, just take it out and shake it. if you hear a ball inside rattling freely, then its fine.
Old 04-07-2007, 08:01 PM   #8 (permalink)
I hate 5SFEs
conor's Avatar
View conor's Photo Gallery
First thing you should do is to check trouble codes.. If you're not keen on DIY, any el-cheapo shop with a $99 code reader should be able to tell you what's going on.. some will even do it for free. That will save you the most time and money, spending cash on stuff your car doesn't need.
Conor :::: Life is blueish silver...
1993 V6 MR2
1986 MR2
1992 Camry LE
conor is offline   Reply With Quote
Old 04-08-2007, 11:41 AM   #9 (permalink)
Gameroom cash: $303055
I agree with nodrogkam, clean the throttle body and the idle air control valve. Here's a link to a DIY thread on the cleaning:
http://www.4x4wire.com/toyota/mainte...throttle_body/
There is also a good thread on this forum with some great pictures. Do a search for "throttle body cleaning". Note the square or diamond shaped hole in the base of the throttle body. That is the port that leads to the idle air control valve. Spray that liberally with the cleaner and let it soak while continuing to clean the rest of the throttle body.
MIke
My experience w/ a 07 Camry SE I4 auto Linck 5th & 6th Generation (2002-2006 & 2007-2011) 49 08-14-2007 08:05 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
98 camry 5FSE to 3SGTE S13/R32 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-09-2004 07:56 PM
