O2 Sensor help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2007, 01:12 PM   #1 (permalink)
View susptech's Photo Gallery
3rd Generation O2 Sensor help
I have a 96 Camry with dual O2 sensors. I want to install headers from a 94. I noticed on other pre 95 Toyota cars, the port that the post-cat O2 sensor is plugged into on mine, is capped off. Does this mean there is a dummy resistor plugged in behind the cap? If so, how universal are they? Can I install one off, say a 94, and trick my computer so I only have to run the primary O2 sensor? Or am I just barking up the wrong tree?
susptech is offline   Reply With Quote
Old 04-09-2007, 08:34 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
with the OBDII on your 96 camry and not on the 94, you need to use both oxygen sensors or else get ready to see that CEL on your dash. on pre-95 cars the catalytic converter wasnt monitored so there was no need for the second O2 sensor, but in 96 it is (speaking from a guy who had a cat go bad on his 96).
Old 04-09-2007, 08:39 AM   #3 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
The pre-95 I4's dont, but the 94 and 95 V6 are OBDII, and have 3 O2 sensors.
geoff5093 is offline   Reply With Quote
Old 04-09-2007, 01:26 PM   #4 (permalink)
View zirconx's Photo Gallery
Yes you can trick the computer with an o2 sensor simulator. Only about $30. I did just that in my 97 Avalon a few weeks ago. Should be about the same in your Camry. http://toyotanation.com/forum/t186167.html
If you eliminate it completely (sounds like you'll need to do this), then you'll need to also wire up a power resistor to simulate the o2 sensor heater, otherwise you'll get an error code for that. I have pics of how I did that in my post, too.
zirconx is offline   Reply With Quote
Replaced my downstream o2 sensor with a simulator (many pics) zirconx 1st Generation (1995-1999) 11 04-26-2012 11:52 AM
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Error code 21 O2 heated Oxygen Sensor failure pkmorreira 89-95 Toyota Pickup/Hilux 11 02-05-2011 03:02 PM
2000 Echo - O2 sensor failure Ashla Yaris, Vitz and Echo Forum 4 03-15-2006 03:48 PM
