Whats up guys, I figured all you tech experts can answer the questions I have about this big brake install. The Ksport Techs has been hard to get a hold of recently, maybe on vacation i dont know. Anyways I have listed them below. The instructions i recieved from them suck because it leaves to many questions and room for error which is not good when it comes to brakes...Also thru up some pics so you can see what they look like, just fitted of couse...
http://www.cardomain.com/ride/686310
1. Apperantly my 19in rim does not clear the caliper. What would you recommend for a spacer, 2-3mm? I dont need much space but need something. Is this going to affect the braking performance/handling? I would have to assume when doing the drum to disc brake swap in the rear (Because this is a 4cly) I am going to need a spacer there also? Ive only seen H&R spacers and 5mm was the lowest. Maybe a custom one needs to be made?
2. When fitting the caliper onto the rotor. Is there a recommended clearance between the brake pads and the rotor? Should the brake pads fit snug against the rotor when test fitting, because mine do not. I would have to assume that because there is no brake pressure the caliper is not compressing the brake pads to the rotor.
3. Should I use the stock shims with the brake pads to close the gap between the rotor and the pads or are they not necessary.
