Replacing remote start/Keyless entry system..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2007, 08:55 AM   #1 (permalink)
View Xkontour98's Photo Gallery
3rd Generation Replacing remote start/Keyless entry system.....
My wife has a 95' LE and the previous owner had a remote start/keyless entry system put it in. The remotes are crapping out and I can't seem to locate replacements, so I am debating putting a new system in. I have never done any under dash wiring before, and would normally not attempt it, but being that their already is a system in there I am contemplating giving it a shot. If all the wirirng is there, it shouldn't be too difficult to follow and replace the system with a new one, right?
I'm pretty much looking for some advice from those that have done an nstall before as to if I should give it a shot or pay the $270 and have Best Buy install a new system. If there is anyway I could splice the existing systems wiring and copnnect it to the new "brain," I think that would be doable, I just don't know enough about the systems and instll to know if this is feasable or not.....What do you think.... I know if it haddn't already had a system in it I would have a pro install it, but being that the wiring is already there, it's tempting to give it a shot!
Xkontour98 is offline   Reply With Quote
Old 04-09-2007, 12:53 PM   #2 (permalink)
View FireFire's Photo Gallery
It depends.
I just done it two weeks before. You have to compare the two system and find out what diff they are. Most wire will be remain the same. But you still have to find out some special wire they are not used in the old system. So, on the other hand, if your new system is using the same wire as before. You just need to figure out which is which and hook it up.
FireFire is offline   Reply With Quote
Old 04-09-2007, 02:26 PM   #3 (permalink)
View zirconx's Photo Gallery
I think its fairly easy to do. You can get the wiring charts from several places, including bulldogsecurity.com.
You can get a simple keyless entry kit for around $40 - http://www.partsexpress.com/pe/showd...number=330-145
But if I were going to the work of installing a new system, I would get one with a remote starter. I think you can get decent ones on Ebay for $70 on up. But they are harder to wire up.
And lastly, you should be able to find a replacement remote on Ebay for around $25-35, which would be a lot less work than installing a new system.
Good luck.
zirconx is offline   Reply With Quote
Old 04-09-2007, 02:29 PM   #4 (permalink)
Whoops, sorry didn't realize this was for an aftermarket unit. In that case, I understand why you can't find a replacement remote.
It shouldn't be too hard to wire up a new unit, since all the wires have already been tapped, but still you'll need to figure out what each wire is for, unless you can find the wiring diagram for your existing unit.
Old 04-09-2007, 02:32 PM   #5 (permalink)
I think that is going to be the catch!
Old 04-09-2007, 04:59 PM   #6 (permalink)
Gameroom cash: $303055
Even though the system is not OEM, you should still be able to get new remotes for the system. Do you know the vendor? It should be on the remotes. Look up the vendor and go to their website. Try to find a dealer in your area and give them a call or contact the vendor directly. Last year I got a new remote for the DEI keyless entry system on my 94 Camry. One had gone bad, the other still worked, so I new it was the remote. That would be cheaper and a lot less work than installing a totally new system, IMHO.
Mike
Old 04-09-2007, 05:32 PM   #7 (permalink)
Sleepin zZzzzz
360glitch's Avatar
View 360glitch's Photo Gallery
Keylessride.com carries aftermarket replacement remotes, you might want to check them out.
'01 Avalon XLS - Project Log
'92 Eagle Talon TSi AWD - Project Log
360glitch is offline   Reply With Quote
Old 04-09-2007, 07:43 PM   #8 (permalink)
Don Lazie Joker
View DonLazieJoker's Photo Gallery
Ill go with Viper alarm because if anything goes wrong with it you can just take it to any licensed dealer to get it fixed.
Don Lazie Joker's Ride
http://www.cardomain.com/ride/852013
http://hincity.com/donlaziejoker3
[image]http://i3.tinypic.com/2ujjjht.jpg[/image]
DonLazieJoker is offline   Reply With Quote
Old 04-09-2007, 08:09 PM   #9 (permalink)
View sanfelice's Photo Gallery
i got a new remote for my system a couple of years back, even though the remote looked different than the original. good luck.
sanfelice is offline   Reply With Quote
Old 04-10-2007, 12:30 PM   #10 (permalink)
That's what I have on my car! The 2way remote alarm/starter. Have brought it in many times over the 4 years I have had it. Well worht the money!
Thanks a lot man! I will have to check that out!
Old 04-12-2007, 10:02 PM   #11 (permalink)
You're the man! They have my remote! Lets hope this solves our problem now!!!
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Remote entry? 02RSX90camry Camry & Solara Lounge 12 03-30-2006 10:22 AM
2005 rav4 remote start/keyless entry bml1306 General Discussion 0 12-01-2004 01:32 AM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
2001 Corolla Remote Entry 2001rolla Archived Corolla threads 0 12-18-2002 10:47 PM
