Do you think the car would break down?
Id change the timing belt or at least check it, remove the top cover and look. If it looks ok you could put it off for a while but i'd say i'd do it within the next 50k since you dont know the history.
Is there any other good way to the timing belt?
Change it or get it changed? This post might help, its not exact but alot of the details are close.
http://www.toyotanation.com/forum/t160972.html
You can also download the factory manuals here.
http://oregonstate.edu/~tongt/camry/
How can i check the cars service records?
Probably can't unless you can get some receipts from the owner. Id assume nothing was done like coolant, transmission fluid and t-belt and just do them; and inspect everything else like the brakes.
