Transmission question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2007, 07:38 AM   #1 (permalink)
View charliep's Photo Gallery
I just replaced a damaged transmission in my 92 Camry 4 cylinder. Everything went in no problem. On the axle side of the transmission I found a wire to plug in but the sensor is missing from the replacement transmission. It's a two conductor plug. I looked at the original transmission and sure enough there is a round sensor on the side with wires that the replacement does not have. What does this sensor do and will the car run without it. I though all Gen 3 transmissions were interchangeable?
charliep is offline   Reply With Quote
Old 04-11-2007, 10:59 AM   #2 (permalink)
View toyomoho's Photo Gallery
There could be some minor differences between the transmissions. Can you post a photo of the old part or describe more accurately its location, what color wires lead to it? Suggest downloading the trans info from the link below and locating all the parts that are wired to the harness.
http://oregonstate.edu/~tongt/camry
Old 04-11-2007, 12:05 PM   #3 (permalink)
Sorry don't have a camera. The sensor is a round device located near the grease shield for the drivers side axle. On the old transmission there is a bracket that holds it into the trans. The new transmission doesn't even have the hole. I've look thru the transmission manual and was not able to see the connector. Any more ideas?
2002 Tacoma Transmission Oil Cooler Install Question GentlemanJack 1st Generation (1995.5–2004) 1 09-25-2006 06:13 PM
Transmission Question 92_Gen3_5SFE_LE Camry & Solara Lounge 4 06-14-2006 10:30 AM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
MR2 Transmission Question mblnnash MR2 Forum 9 11-02-2004 06:46 PM
MR2 / Camry Transmission Question mblnnash Camry & Solara Lounge 1 10-31-2004 11:53 AM
