pure gasoline smell on startup...help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2007, 11:32 PM   #1 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
Question pure gasoline smell on startup...help
Well today i took my friend home, and he told the the car was running rich, he smelled the exhaust smelled like pure gasoline, he said the O2 was gone...Is he right or can it be something else?
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 04-13-2007, 10:37 AM   #2 (permalink)
Gameroom cash: $303055
It can be many other things if the car is actually running too rich. It can be a defective ECT sensor (engine coolant temperature sensor), a thermostat stuck in the open position, defective fuel pressure regulator, leaking fuel injectors, or a bad ECU, just to name a few. You can't just guess O2 sensor. You really need to do some diagnostic work here. Start by checking for engine trouble codes. Your picture looks like a 97-99 Camry, so your car should be OBD2. That means you can take the car to Autozone and they will check for codes for free.
Mike
Old 04-13-2007, 10:54 AM   #3 (permalink)
Creeps228's Avatar
the only code that apears is the egr valve code...p0401 i think it is, i still havent gotten it fixed yet, could it be that?
MR2: 7A-GE
Old 04-13-2007, 12:07 PM   #4 (permalink)
View F1000X's Photo Gallery
I'm a bit shady on emmisions systems, but here is my $.02. Maybe its possible the EGR system is staying open beyond normal operation and pumping excessive dirty air back into the engine. As a result, poor combustion, and voila, you smell gas out the ass end of the car. Is the car missing at all?
I'm so tempted to make a Sex Panther (Anchorman) joke right now. Now whenever someone gets into your car and asks what the smell is, just say "Thats the smell of desire M'lady."
Sorry, just had to. Good luck with your problem.
Wishing for a 2JZ
1993 Toyota Pickup, Bomz Racing Intake, TRD Shift knob, NGK Spark Plug Wires, Addco Rear Sway Bar, Tonneau Cover, Bitchin' Tailights, 100% Poly-bushing Rear Suspension, Bilstein Shocks, 17x7 Kobe K5s wheels on Hankook K106 tires, Detroit Truetrac, and more to come.
F1000X is offline   Reply With Quote
Old 04-13-2007, 12:12 PM   #5 (permalink)
Creeps228's Avatar
LOL
But only during a cold startup...had the car checked before, mechanic saidi nothing was wrong with it...idk, jus soem suggestions would work or is it normal
MR2: 7A-GE
Old 04-13-2007, 12:31 PM   #6 (permalink)
Hmmm. Sensor in the EGR system is supposed to keep it closed below 55 Celcius. If its staying open I'd assume the car would miss a little, and possible produce the smell. I assume engine feels (and smells) normal while driving, right? Again, good luck.
Wishing for a 2JZ
Old 04-13-2007, 12:51 PM   #7 (permalink)
Creeps228's Avatar
yes it does runs greatt after warm up
and i've cleaned the egr mod, havent changed the egr valve and changed vsv valve. stupid code comes up still
MR2: 7A-GE
Old 04-13-2007, 12:55 PM   #8 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
Y'know, 60% of the time, it works every time...
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 09-17-2007, 08:54 AM   #9 (permalink)
The bucket owns you!
ChevelleSSLS6's Avatar
View ChevelleSSLS6's Photo Gallery
is the coolant temp sensor (3sfe) on the front drivers side of the mill, near the top of the cylinder head?
ChevelleSSLS6 is offline   Reply With Quote
Old 09-17-2007, 10:25 AM   #10 (permalink)
Creeps228's Avatar
i have no idea, i dont own a 6 cylinder engine..and i do think my egr valve is in the open position, but Oh well, shit happens
MR2: 7A-GE
Old 09-17-2007, 11:36 AM   #11 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
if that happens on cold start only then its normal. on my, when cold starts it automatcially goes up to about 1800 rpms and as the engines warms up its goes down. once warmed up its go about 700-800 rpms. just my two cents.
Black95Cam is offline   Reply With Quote
Old 09-17-2007, 11:38 AM   #12 (permalink)
Creeps228's Avatar
i know that, im just saying, even though this thread is old, that everytime i start the car theres at pure gas smell fro like 10-15 secs
MR2: 7A-GE
Old 09-17-2007, 03:09 PM   #13 (permalink)
Black95Cam's Avatar
lol.. didnt even notices the date..
Old 09-17-2007, 04:31 PM   #14 (permalink)
As you are standing in front of the engine, it's on coolant port coming out of the right side of the cylinder head. It is the sensor under the green plastic connector.
Mike
Old 09-17-2007, 06:04 PM   #15 (permalink)
Creeps228's Avatar
bkack95cam its ok for the thread jack, but while we're on the topic of exhaust system...theres a stinky smell ( rotten eggs ) everytime i accelerate i just want to make sure that its the catalytic converter? It really getting on my nerves
MR2: 7A-GE
Gasoline smell at start up? Ghost Archived Corolla threads 0 05-23-2006 02:54 PM
gasoline smell in engine bay Redline Camry & Solara Lounge 4 03-29-2006 01:05 PM
Gasoline smell inside cab zborg 2nd Generation (2005+) 10 12-04-2005 06:16 PM
fuel smell upon startup 92 camry? TonyD 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-22-2005 10:20 PM
