96' Camry won't stay running ... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2007, 08:31 AM   #1 (permalink)
View Pezman04wrx's Photo Gallery
My better half's 96' Camry (4cyl) starts up just fine if you stay on the gas (2k-3k rpms), but if you let off the gas the car just dies ... It's done it in the past, but has always gone away after a couple seconds of keeping the rpm's up ... Any thought's?
- 04' wrx ... It get's up and goes ...
- 96' Camry ... What it had, got up and went ...
Pezman04wrx is offline   Reply With Quote
Old 04-13-2007, 08:59 AM   #2 (permalink)
View geokor's Photo Gallery
iac (idle air control) valve gets sticky from carbon build up. It has to be cleaned or replaced. One technique of cleaning can be done by just removing intake hose and squirting throttle body cleaner into the square hole located on the lower portion of the throttle body intake area. Also clean air control flap while your at it. Then put everything back and start car. It will hesitate for half a minute, but push the pedal until it clears up. If that does not work you have to remove throttle body and get to IAC valve. Remove it and supply 12v to the terminals and see if valve is functional, also check resistance. You will need a manual to do this right. If everything checks out right you will be able to clean that valve directly while it is in your hand (best way). If that doesn't do the job, it may have to be replaced. I've seen those valves test out fine but function weakly, compared to a new one. Good luck.
geokor is offline   Reply With Quote
Old 04-13-2007, 11:41 AM   #3 (permalink)
The only thing that would make this site better is if someone actually came over to my house to do the work ... ... Honestly though, searched on the IAC valve and found this wonderful gem of a thread http://www.toyotanation.com/forum/t158097.html ... Went home for lunch and fired it up ... Still stalling out, so I douched the IAC valve area and TB, came out of the house 15minutes later and it runs like a top ...
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
New Member, '96 Camry Tire Question camreality Introduce Yourself Here 2 06-04-2006 01:08 PM
96 Camry V6 LE: TRD supercharger? kman10587 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-16-2004 03:15 PM
96 Camry side mirror sourcerer 3rd & 4th Generation (1992–1996 & 1997–2001) 2 04-12-2004 12:05 AM
