when should i lube uppp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2007, 01:54 PM   #1 (permalink)
View devild599's Photo Gallery
4th Generation when should i lube uppp
how many miles should i go till i get a transmisson flush.... its at 49k and it was change (not flush) at 40k
devild599 is offline   Reply With Quote
Old 04-13-2007, 02:32 PM   #2 (permalink)
View toyomoho's Photo Gallery
One suggestion is you just keep changing the fluid instead of flush. This is a very easy DIY job that can be done when changing the oil. A lot of people does these every 30K miles.
Old 04-13-2007, 06:43 PM   #3 (permalink)
View hassanbigboss's Photo Gallery
hey man...you dont have to do any flush or anything like that.....just a drain and fill.....this is how I did with my Camry....it has 137xxx miles on it and the transmission is silky smooth....btw...I did get my trans flushed because I bought my car used so I didnt know how the last owner had treated it.....but since your car has only 49000 miles and I am assuming you are the fist owner....just keep doing the drain and fill and your trans will be just fine....drain and fill a couple of times or till the fluid that comes out is clear and or nice cherry pink....that is when you will know your trans fluid is completely clean....goodluck and tell us how it goes.
hassanbigboss is offline   Reply With Quote
Old 04-13-2007, 06:56 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
I would just drain and refill maybe once every other oil change 2 or 3 times. That should replace pretty much all the fluid. Draining the pan gets about 2/5 of the fluid out.
If you have the I4 automatic, you didn't state what engine and transmission you have, you should drain and refill the differential also if it has not been done. It takes 1.6 or 1.7qt IIRC. Just fill it to the bottom of the drain hole.
2007 Camry 2.4L 5M
Old 04-14-2007, 02:34 AM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
30K drain and fill is recommended for normal driving. If you are stuck in a ton of stop and go and or have a lead foot, you may want to change a little more frequently.
nodrogkam is offline   Reply With Quote
Old 04-14-2007, 08:37 AM   #6 (permalink)
View krgs4's Photo Gallery
DIY Drains $18 each time....get 10% fresh fluid...I've never felt a difference
Shop Drains $30 each...same as above.
Shop T-Tech Full Tranny Flushhhh.... $89-$99...totally different car..like brand new...smooth, like it was brand new...feels like it pulls harder ...no hard shifts...worth evey penny.
I was doing DIY drains every 10K miles till I got to 50K and then did the T-Tech Flush.
It is a world of difference.
krgs4 is offline   Reply With Quote
Old 04-14-2007, 09:40 AM   #7 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
Every 50k is a good rule imo.
And i can't beleive that a post title stating "when should i lube up?" made it past all you guyss without being ripped on. I am truly shocked.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 04-14-2007, 10:17 AM   #8 (permalink)
nodrogkam's Avatar
lol maybe we're more mature....
I did a T-Tech once, it did make a world of difference, but only if you let the fluid get too dirty in the first place (which i did.)
Old 04-14-2007, 11:28 AM   #9 (permalink)
View solidg's Photo Gallery
4th Generation
I have a trans flush done every 30k Im at 115k now
solidg is offline   Reply With Quote
Old 04-15-2007, 01:05 AM   #10 (permalink)
View leasaunce's Photo Gallery
I went to Toyota , they did my Transmission Flush. It costs about $60aud, took them about 1.5hr.
I asked them how often i should do a transmission flush, they said it is recommended twice per year, but once a year is alright.
IMO doing a Transmission flush was well worth the $$$, I noticed the difference. Gear changes much more smoother. I THINK I NEED ANOTHER FLUSH, it has been more than a year now since my last FLUSH.
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 04-15-2007, 01:09 AM   #11 (permalink)
I was actually gonna say "before you stick it in" or "before you meet rosy palms and her five friends," but I decided against it...
2007 Camry 2.4L 5M
Old 04-15-2007, 01:22 AM   #12 (permalink)
nodrogkam's Avatar
^ hahahahahhahaha
so dirty...
Old 04-15-2007, 06:12 AM   #13 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906627
iTrader Score: 59 reviews
I was going to say the same thing!! ...thought better of it tho!! On topic, I usually get my trans serviced yearly, and always feel a different afterwards, much smoother shifts!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 04-16-2007, 10:54 PM   #14 (permalink)
Insert Custom User Title
BigPete's Avatar
View BigPete's Photo Gallery
This is too good to let go lightly.
How about before you go to the dealer to do whatever work you're talking about doing in this thread.
1999 Toyota Camry 1MZ-FE 5spd
BigPete is offline   Reply With Quote
Tranny Oil Xlerator 1st Generation (1995.5–2004) 3 03-19-2007 05:02 PM
Jiffy Lube messed up my '94 Corolla! jinster Archived Corolla threads 14 09-24-2006 07:51 AM
Jiffy Lube stevenh563 Off Topic 21 06-15-2006 11:50 PM
Transaxel Lube yaitisme Tercel, Paseo, Starlet, and Sera Forum 6 09-29-2005 04:53 PM
clean lube and adjust brake? stanleyeye Camry & Solara Lounge 2 07-01-2004 04:57 PM
