Circuit help - scanning led - ground when off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2007, 08:14 PM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
The LED on my alarm pooped out. Trying to install a scanning led to replace it. How do I wire the thing, need to know what circuit grounds itself when the car is off and where to get a constant 12v power source.
WhiteRabbit is offline   Reply With Quote
Old 04-14-2007, 07:44 AM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Can't you use the original wiring for the LED? If you use a constant 12v power source, then won't the LED be on all the time? Or are there three wires, ground, constant and trigger? You can typically grab it from your stereo, as it needs a constant for memory.
Silver Streak is offline   Reply With Quote
Old 04-14-2007, 09:45 AM   #3 (permalink)
Boss Honky
YESCA's Avatar
iTrader Score: 29 reviews
View YESCA's Photo Gallery
^^^ Thats what I was thinking.
OG Team HAMSTER
O.G. Team HAMSTER violated my mom for food stamps
OHIO FORCE!!!
YESCA is offline   Reply With Quote
Old 04-14-2007, 10:46 AM   #4 (permalink)
View fox_prime's Photo Gallery
How did your LED blow out? To be on the safe side, hook it up in series with a resistor:
existing wiring circuit ----- +LED- ------ 330-ohm resistor ----- GND
fox_prime is offline   Reply With Quote
Old 04-14-2007, 04:38 PM   #5 (permalink)
TN's furry friend
well i dont think the led blew out, i think a connection came loose
wasnt sure if i could use the same wiring for the led since the alarm sends diagnostic blinks, dont know how that would work with a scanning led
wanted to wire to a constant 12v and to a circuit that grounds when the car is off so that it only turns on when the car is off and turns off when the key is put in the ignition
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
