Ok I'm a bit confused. Im still gathering parts for the manual swap. In my spare time I've been trying to read up on the axles and stuff... I'm a bit confused tho.
The part I need to get is the Intermediate Right Axle (jack shaft) from 92-93 V6 Camry
What terminology is used when reffering to this part in lets say a haynes manual??
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Thanks for the help, I do see that in there. Gotta keep checking I suppose.
94' Camry V6 - Sold
99' GS300 - Sold
Im gonna bump this up a little in case anyone else wants to chime in with a little more info or knows how/where i can obtain this part.
Thanks.
94' Camry V6 - Sold
99' GS300 - Sold
the cv shaft is usually sold as one unit with the intermediate bearing. the bearing is replaceable, but likei said, its sold as one unit. you'll have to get the mounting plate that bolts to the block to hold the intermediate bearing in place.
Ok so the unit I have to buy to get the intermediate right axle is called?
(Im looking for CV shaft but i dont see that on car-part.com
On ratkos swap notes he also mentions
Intermediate Right Axle (jack shaft): the 1MZ jack shaft is different than the 3VZ jack shaft so it needed to be ordered. The outter right axle is still the original 1MZ axle, same with the axle bearing mount.
94' Camry V6 - Sold
99' GS300 - Sold
pick up a solara/gen4 camry tranny and skip the trouble
as well, since you're going boost, the newer trannies will hold up better with lower mileage and newer synchros
So with this tranny the only parts I'll have to continue to add will be the ones below, and i wont have to touch any jack shaft, shaft jack, drive shaft, cv shaft, shaft shaft or whatever the hell its supposed to be
Flywheel (fidanza)
Clutch Kit for 92-93 V6 5-speed Camry (Anyone know of any good kits out there? I was looking at an exedy)
Shifter assembly from 94-96 4-cyl Camry (have)
Shifter cables from 94-96 4-cyl Camry (have)
Interior Shifter Trim piece from any 92-96 Camry (have)
Clutch and Brake pedals from 92-96 I4 Camry (have)
Clutch Master Cylinder from 92-96 I4 Camry (have)
Center Console and E-brake handle from 92-96 Camry w/ Hand Brake (have)
E-brake cable from 92-96 Camry w/ Handbrake (have)
OEM Flywheel, clutch, and transmission bolts (Im pretty sure i can find this)
yes?
94' Camry V6 - Sold
99' GS300 - Sold
Flywheel (fidanza)
yes?
yup, basically. but just remember that the clutch and flywheel can also be from the gen4 camry, solara, or mr2 as well. if gives you a lot more options that way.
myself, I'm going with a stage III spec clutch and fidanza flywheel for the camry/solara even though the mr2 one is 1 lb heavier
and #$@#!$#!$ you americans and your easy to find parts....
I can't find the shifter cables or pedals up here in Canada...the junkyards are bare right now...
HaHa
"Life is a deep sleep, of which love is the dream..." Ripped...and the girls are loving it.
If I come across any more before you get yours ill hit you up and send them your way. ; )
I saw a centerforce clutch kit rather than the exedy, not sure yet
Thanks again for all the info!
What would you recommend for a clutch kit?
94' Camry V6 - Sold
99' GS300 - Sold
^ I'll hold you that your word on those shifter cables....they're a fortune new from the stealership.
and I've herad great things about the Spec stage II+ and stage III clutches, so that's why I'm going with Spec. Most of the solara guys use Spec as well- all with great reviews.
centerforce has also been looked at as pretty decent. not many toyota guys seem to use exedy performance clutches though. most use the exedy oem replacement if they do use exedy.
you can browse around solaraguy.com for more boost related info- plenty of info on there
HaHa
94' Camry V6 - Sold
99' GS300 - Sold
