Decided to clean engine and... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2007, 11:43 AM   #1 (permalink)
View titoisme's Photo Gallery
So I decided to clean my engine today (can hardly see it under the grease, rat turd and other niceys). I bought some cleaning solution and got out the hose. Covered the dist cap, that's it. After washing out the engine I let the car sit and decided to clean the whole car. Afterwards, about 2 hours later I take the car out for a spin, drives nicely until it shakes, sputters and dies on me. I try to turn it on after a few min but it just turns, no combustion tough. So I decided to pop the hood and check out the spark plugs and, damn, it seems water has seeped in there from the cleaning. So I dry out the area and inside the spark compartments. Wait a little while and turn the key and it turns on, but now with a terrible vibration when idle. Was able to get it home w/o dying. Is it just a matter of letting it dry out or could something have fried?
PS: Please don't tell me how dumb I was, I've been beating myself up enough. LOL
Thanks
titoisme is offline   Reply With Quote
Old 04-14-2007, 12:02 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
you should cover the distributor cap AND alternator/starter ....
but sometimes the cap gets wet even when covered - mine took 24 hrs to dry ... it should be fine after you let it dry a few more hours, nothing is permanently damaged i dont think
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 04-14-2007, 12:15 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
how much water? if u have water in your spark plug channel then thereas a good chance that it may have gone into the engine, that could be causing the stumble if theres water in the oil system. id change the oil or at least check it to be sure. weve all done stupid stuff
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-14-2007, 12:29 PM   #4 (permalink)
View toyomoho's Photo Gallery
Recheck for water in the spark plug tubes, inside the ends of the plug and coil wires, distributor (cap and sensors), coil, ignitor, MAP and IAC connections. Might try using a hair drier around the connections.
Old 04-14-2007, 12:31 PM   #5 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I've done worse. It should be fine. when was the last time you replaced the Dis cap, rotor, and wires anyway? (Miles and time)
5 Lug Corolla WHAT?
Old 04-14-2007, 12:39 PM   #6 (permalink)
I haven't, but I'm planning to change them once spring FINALLY decides to come my way. hehe. Also, how bad would it be if water did enter the engine through the spark tubes?
Thanks for all your replies, keep'em coming if you have anything else to offer.
Old 04-14-2007, 12:44 PM   #7 (permalink)
It should not be enough water to cause any kinda of long term issues. If the Disi cap and rotor are original, even being covered, water could have gotten in. Also for the wires, if those are old, the water directly on them could be the cause. It's not likely anything you did, but just old wires/cap/rotor.
5 Lug Corolla WHAT?
Old 04-14-2007, 12:59 PM   #8 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
id just let it burn off, replace the plugs, wires, cap, rotor, etc do a seafoam, maybe that will help?
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 04-14-2007, 01:14 PM   #9 (permalink)
Venom_5's Avatar
i wouldnt replace the distro cap or anything yet...
getting them wet once doesnt destroy them... let us know what happens after waiting a day and starting the car up ... let it run for an hour or so (drive it around) ... if the problem still exists then you can replace parts
ive taken a Land Cruiser through puddles and stuff soaking the distro cap weekly and it still holds up fine after it dries out - no need to spend money just yet
Old 04-14-2007, 01:24 PM   #10 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
yeah i'd say let it dry out. Double check the plugs to be sure they are still in good shape, and make sure the plug wire caps are dry too. just air out the darn thing.
The rough idle is due to one or more plugs not firing or firing correctly, no real damage done.
nodrogkam is offline   Reply With Quote
Old 04-14-2007, 02:06 PM   #11 (permalink)
View Red Camry's Photo Gallery
do you atleast have a pic of the cleaned engine?
CAMRYcoupe
Red Camry is offline   Reply With Quote
Old 04-15-2007, 12:07 AM   #12 (permalink)
I HAS BOOST!!!
bigbird's Avatar
yeah! screw ur problems...we want some pics!!
R.I.P.
Car Domain:
Old 04-15-2007, 10:34 AM   #13 (permalink)
View SilvaCam92's Photo Gallery
i cleaned the engine on my moms ford probe last year. july 4th right before the fireworks. anyways ya i cleaned it and it wouldnt start. so we went to the fireworks and about 3 hours later i tried to start it. still wouldnt start and so i took the spark plug wires and there was water in there so i tapped them to get water out. had to do it quite a few times and then my mom started it and it was sputtering really bad so she held it at like 4500rpm for a couple of mins and then the cat started glowing orange/red so we shut it off. let it sit for a day and started it up. still sputtering so we brought a mechanic to look at it and he bought it spark plug wires and it ran perfect again!!!
sorry for the long unessesary story but i thought id add details lol
3/24/12 - 250,000 miles
http://www.cardomain.com/ride/2593921
SilvaCam92 is offline   Reply With Quote
Old 04-16-2007, 03:33 PM   #14 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
LOL, and how does a car (i know you misspelled) glow orange/red?
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 04-16-2007, 07:44 PM   #15 (permalink)
Maybe he meant CATalytic converter...? lol
I'll take a pic of the engine, still kinda ugly, but I can read off it again...lol.
PPPS: What size ratchet I use to unscrew sparkplugs, 5/8?
Thx
looking to buy a 88 Supra(california Emissions) chi-toy Supra Forum 3 12-09-2007 08:09 AM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
Part Deux; 20R REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 21 09-06-2007 09:35 AM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
ways to clean up the engine bay vrt_firestarter MR2 Forum 14 10-21-2004 09:53 AM
