Please Help Me Find Out Where This Wire Goes for 93 V6 Camry!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2007, 11:21 PM   #1 (permalink)
View walay's Photo Gallery
Question Update 4/26 More!! Help Me Find Out Where these Go for 93 V6 Camry!!
5/10 Update:
The car has been repaired at TNT Repair Service Inc, and it runs great and smooth now. The only thing replaced was one of the Fuel Injectors, but after all this, I decide to sell it off, because I realized that a V6 is too much work for me if somthing went wrong in the furture, an since I got this car for a great deal from a friend's mother, I might get more money back and able to find a 4cylinder car
Thanks all for your help, and now I will try to find a 4cylinder corolla/camry
Thanks!
4/30 Update:
After some test driving this past weekend after replacing the Vacuum Switching Valve, the crazy vibration and rpm raise or drop and jerk when chaning shift positio are alot better. However there are still other problems such as vibration during ideling and acceleration, and seems to be lost its power, which I believe might be caused by soemthing else...at this point I'm thinking timing belt or somthing else that i just dunno about.
Anyways, I give up since I really don't have the right equipments to dig deeper, so I took my car to "TNT Repair Services Inc" in Oceanside, CA as recommended by our fellow TN member 'dlichterman'. Hopefully they will pin out the problem for me, and I can share it with you guys with the similiar problems.
I will update this as I find out more.
4/26 Update:
Thanks for the help guys, the major problem is now fixed after I replaced the Vacuum Switching Valve as suggested by csaxon.
Also according to renmike I will let shop check my timing next....since I'm not sure how and dun have the equipments.
and I will also check out the engine mounts after these following things are fixed...Seems to be a PITA to replace engine mounts...i wonder how much shop would charge...
Anyways, so since I feel the car still isn't as smooth as before, I poked around more and find some other loose connections again, so again, help me out guys find out Where/if these connectors connects to anything. Thanks very much.
Unknown connection 1:
Unknown Connection 2:
Thanks ~
4/16:
Thanks for the help, so according to Midnightmach, that plug doesn't go anywhere,
then what can be the cause this problem shown in this video I took.
http://www.viddesign.net/camry
(For those also wondering the same thing, this wire dosen't connect to anything as noted by midnightmach)
http://www.viddesign.net/camry/camry1.wmv
http://www.viddesign.net/camry/camry2.wmv
When start-up the engines Revs to 2000rpm.
then drops down to a little over 1000rpm after about 1min.
then once shifts from P to Reverse or Drive, the engine jerks and the car seems to jerk/jump forward
or back depends on if you shift to D or R. then the rpm drops down below 1000rpm, after shift engages.
Even when the car is warm, once shift to P or N, the rpm rev back to a little above 1000.
And during all this time, the engine/car vibrate and shakes, and a very strong smell of gas and white smoke comes out from exhaust.
This is a V6 where engine suppose to be smooth and not rough, it happened the day after I purchased it while I was driving and drove over a regular bump in shopping mall at normal speed.
After this happened, I thought something went lose and replaced spark plug, spark wires, distributor cap, rotor, engine gasket, air filter, cleaned throttle body, changed oil, but problem remains the same.
So does someone have an idea? I really need this car running, and its kinda dangerous to drive like this.
Let me know if additional info is needed.
4/14 Posted:
Just found this forum and hope someone can help
I recently purchased a 93 Camry V6 from a friend,
car ran smooth until I went over a bump on the road.
Engine starts to rev high, the whole care vibrates and jerk when changing tranny position.
for example when move from P to D, or to R the whole car would jerk.
Look insided the engine and I found the following wire not connected and this green thing broken in half/which I glued back together, let me know if it would effect anything.
So my problem is, I'm not sure where this connector goes. Please help and maybe take a pic to show me where it suppose to go. Thanks.
I've looked in the manual but still can't figure it out.
I Highlight the wires in red.
(This is the Vacuum Switching Valve that fixed the issue pointed out by csaxon)
walay is offline   Reply With Quote
Old 04-15-2007, 08:36 PM   #2 (permalink)
Official TN user
Tuner571's Avatar
View Tuner571's Photo Gallery
As far as gluing that piece together I dont think that would harm anything, but I would still replace it. As for the clip I'm not sure where it goes. I have a 95 V6 and I cant find anything that resembles that connection. Hopefully someone on here knows what that wire goes to.
95 Toyota Camry V6
http://www.cardomain.com/ride/2489322
Tuner571 is offline   Reply With Quote
Old 04-15-2007, 09:21 PM   #3 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
If that plug came off of the alternator harness then mine isnt connected either, but i doubt that is the problem with your car.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 04-16-2007, 12:48 PM   #4 (permalink)
Unhappy
Hi,
Thanks for the help
Old 04-16-2007, 01:03 PM   #5 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
This might sound like an odd question, but when you changed the distributor cap, did you notice if the distributor was bolted on tight? For some reason, when I hear your symptoms, the timing keeps on coming to mind. If you have a friend with a timing light, have them check out what timing you're currently running. I'm thinking that perhaps the distributor was loose and when you hit the bump it moved just enough to throw your timing off.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 04-16-2007, 04:01 PM   #6 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Vacuum Switching Valve if leaking or defective it can cause symptoms you describe.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 04-16-2007, 04:10 PM   #7 (permalink)
Hm, I'll replace it first and see what happens...
Guess if it broke in half, I can't just glue it together
I will update on the result after its replaced hope it would fix the problem...
Old 04-16-2007, 04:46 PM   #8 (permalink)
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Go 3/4 down the page and follow the test procedures for everything attached to the system before throwing parts and money at it!
Old 04-16-2007, 11:08 PM   #9 (permalink)
View tech8's Photo Gallery
Sounds like a vacuum leak from the engine compartment, which very likely has to do with the Vacuum Switching Valve, as csaxon pointed out.
The jerking of the transmission, and some of the engine vibration, may actually be bad motor mounts. The motor mount may already have been bad when you bought it, but only showed up when you hit the bump.
tech8 is offline   Reply With Quote
Old 04-17-2007, 10:03 AM   #10 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
you CAN glue the vsv back together as long as you didn't break the actual switch and can make sure that it's sealed tight
HaHa
Old 04-26-2007, 11:17 AM   #11 (permalink)
More question needs answered...UP
Old 04-26-2007, 05:05 PM   #12 (permalink)
If someone can just take some detailed photo of their engine compartment, that would be great
Old 04-26-2007, 09:20 PM   #13 (permalink)
engineer in training
Gameroom cash: $145055
In the second pic with that open vacuum port, it looks like the line that is supposed to go there is right below the circle you made. That line should go to a large vacuum canister under your cruise control box, then back on top of the engine there and over to the top left of the engine bay, it connects to whats called an ACIS, or part of the intake.
Check on the top of your hood and you should find a vacuum diagram, you will see what I'm talking about when you look at the diagram.
Old 04-29-2007, 04:09 PM   #14 (permalink)
Gosh! can't believe I missed that...i've been looing for it for 2 days...and it was right under my nose thanks much
Old 04-30-2007, 04:46 AM   #15 (permalink)
View superman_143's Photo Gallery
thanks a million
hey i just am wondering where you picked up your vsv valve? i have all the problems you have had in the video and i changed and did all the exact work you have done to your car and i just seen the video and am happy to see one more person out there has the same problems as my car. i was just about to give up on the car but something told me to hold on to the camry. well if you could direct me to where you got the part from i should be picking it up asap. thanks
superman_143 is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Camry V6 XLE wire harness help! CX889 Audio, Video, and Security - Tech 9 12-23-2006 06:34 PM
Need Help: Can anyone help me find TRD Brake Pads for my GEN4.5 Camry V6? NewRacer 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-05-2006 07:25 AM
96 Camry V6 LE: TRD supercharger? kman10587 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-16-2004 03:15 PM
