Gauge cluster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2007, 01:39 AM   #1 (permalink)
View blackxs's Photo Gallery
4th Generation Gauge cluster
I searched and couldnt find anything exactly. I know (well, I can find) what types of bulbs I need, but I want to do a conversion and change the center console and gauge cluster lights over to blue. How many bulbs, where, how... or simply, are there any tutorials or helpful people? Im really looking into doing this, and cant find much information, and this seems to be my best bet.
blackxs is offline   Reply With Quote
Old 04-16-2007, 01:47 AM   #2 (permalink)
View nuron's Photo Gallery
Camrymanuals.com might have some information
nuron is offline   Reply With Quote
Old 04-16-2007, 01:55 AM   #3 (permalink)
it's been a good ride
iTrader Score: 14 reviews
View camry_ricer's Photo Gallery
the gauge cluster uses size 194 bulbs. if you decide to use LED on all 5 bulbs, you are going to need a resistor... for the center panel, they use size 74 bulbs.
camry_ricer is offline   Reply With Quote
Old 04-16-2007, 05:34 PM   #4 (permalink)
Thanks. How many bulbs total in the cluster and how many in the center panel?
Old 04-16-2007, 06:30 PM   #5 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
When talking about the center counsel, are you saying the A/C unit? Because they take two 74 size bulbs. I did mine the hard way, bought two 194 LEDS, had to grind them enough to fit the socket, didn't use any resistors though.
To get to these bulbs
first pull out the thre knobs on the A/C unit and the small handle thing (that allows you to have the vents open or closed)
second remove the two screws on the A/C unit behind the knobs
then remove the radio brezel (spell check)
next step is to remove the four screws that hold the unit to the brace, after doing this all you have to do is remove the cover of the A/C unit and replace the bulbs and then but everything back. But before you do, make sure the LEDS/BULBS are working. All done, but about the guages, your going to have to search for it, they are many DIY out on TN look for them.
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 04-17-2007, 11:12 AM   #6 (permalink)
Check Out That Camry!!!!
CAMRYTUNER20's Avatar
View CAMRYTUNER20's Photo Gallery
http://toyotanation.com/forum/showthread.php?t=185959
Ive done the whole swap. gauge cluster, Hvac system, shift light, trunk light, ash try light, glove box light. any questions just ask.
KEEP THE PIMP HAND STRONG!
CAMRYTUNER20 is offline   Reply With Quote
Old 04-20-2007, 12:09 AM   #7 (permalink)
View krgs4's Photo Gallery
1. Buy FIVE 194 bulbs (they come in a 2 pack) try to get the Long life ones (194LL)
2. Use this link to help
http://www.imagestation.com/album/?id=4291310149.
3. Image 5 will show you the back Five twist off caps.
4. Unplug the old 194s.
5. Take the GREEN 194 bulb covers off and place them on the New 194LLs
6. Plug them back in. If you don't put the GREEN covers back on your Dash will look PINK.
7. Really easy. 6 screws total to unscrew. 20-30 minute job.
* tip do it when it is like 60-70 degrees out so the first black dash bezel is more pliable...and it will pop out easier.
krgs4 is offline   Reply With Quote
Old 04-20-2007, 05:46 PM   #8 (permalink)
Im looking to change the color. So just buy 194 size covers?
Old 04-20-2007, 05:53 PM   #9 (permalink)
5 or 6 194 leds for the gauges, 2 wide angle 74's for the hvac, 1 5 led 194 for the shifter light in the center console area, 1 74 for the ash try, and if you do the trunk is a 194 but id get like an 6 or 9 led for that
Old 04-20-2007, 06:42 PM   #10 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
4th Generation
are those leds plug and play? or do i def have to wire up a resistor? i hope they r plug and play
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 04-20-2007, 07:33 PM   #11 (permalink)
well some people say you need a resistor but ive had mine in for about 2 months with no problems
Bright white gen3 camry instrument gauge cluster w/pics gen3guy 3rd & 4th Generation (1992–1996 & 1997–2001) 9 05-24-2005 11:37 PM
Gauge Cluster Swap cheeba Camry & Solara Lounge 3 10-24-2003 03:28 PM
Gen. 2 V6 gauge cluster question xavior66 Camry & Solara Lounge 10 08-09-2003 05:38 PM
