PSI level on tires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2007, 11:17 AM   #1 (permalink)
View nitinek's Photo Gallery
PSI level on tires
Can somebody tell me to what PSI i should fill up my tires on my 1995 Toyota Camry XLE?
nitinek is offline   Reply With Quote
Old 04-16-2007, 11:27 AM   #2 (permalink)
View fox_prime's Photo Gallery
38 PSI is the standard, or whatever it says on your tires.
fox_prime is offline   Reply With Quote
Old 04-16-2007, 11:36 AM   #3 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
38? o.0
for some reason i think mine is only 30 psi
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 04-16-2007, 11:38 AM   #4 (permalink)
View keithy's Photo Gallery
factory spec says 30psi. But like fox mentioned, most people go between 34-38 psi.
keithy is offline   Reply With Quote
Old 04-16-2007, 02:54 PM   #5 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
The gov/industry experts insist you go by the auto manufacturer's specs which are sometimes under the armrest cover, the driver's door jam, glove box, etc. It should also be listed in the manual and can be found online. (Try google) Having said that, I personally usually run a bit under the tire's max pressure. The real danger seems to be running them too low as they overheat and blow. Too high makes your ride a bit rougher, may wear the center treads too much and in extreme cases cause a loss of handling.
Dave's is offline   Reply With Quote
Old 04-16-2007, 05:55 PM   #6 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
5 Lug Corolla WHAT?
Old 04-16-2007, 07:39 PM   #7 (permalink)
97 Camry
View Davee's Photo Gallery
I always like to go a couple of pounds above manu rating on the door as you typically will wear the tire shoulders at their levels. More makes the ride too rough
Davee is offline   Reply With Quote
Old 04-16-2007, 10:15 PM   #8 (permalink)
mr.pringles's Avatar
View mr.pringles's Photo Gallery
yea, normal psi is 32-35,but you can always add more if you want but make sure you dont exceed the maximum PSI labeled on your tires' sidewall or you will pop a tire while you hit a pothole
mr.pringles is offline   Reply With Quote
Old 04-16-2007, 10:34 PM   #9 (permalink)
Um, I think my tires say 50PSI max. You'll do just as much damage at that.
You so put in what is recomended.
5 Lug Corolla WHAT?
Old 04-17-2007, 12:22 PM   #10 (permalink)
1999 Camry V6 Auto
Eyebrows7's Avatar
View Eyebrows7's Photo Gallery
Don't forget that those recommended tire pressures are for when your when your tires are still cold. If you have to drive over to a fuel station or wherever to check your tire pressure, raise the pressure by a few PSI just to compensate for the heat in the tires.
Eyebrows7 is offline   Reply With Quote
Old 04-17-2007, 01:56 PM   #11 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
most family cars on the road recommend 32 as u can see with the sticker. Thats for a mix of comfort and fuel economy. Too soft for how i drive.
I still like to think 35 psi is the foolproof norm. Also most individuals don't check pressures monthly, so jacking it up a few psi is good so u never have underinflated tires.
Make sure never to exceed max pressure listed on the sidewall of the tire. Some are 35, some are 41, 44, 51 etc...
my 98 with Yokohama H4s w/44psi max, i run 40 front, 36 rear.
nodrogkam is offline   Reply With Quote
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
LOW LEVEL INPUT? dannyset Audio, Video, and Security - Tech 6 01-05-2003 08:10 PM
