Coolant leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2007, 06:33 PM   #1 (permalink)
View bavula's Photo Gallery
Coolant leak
I have a 1998 Toyota Camry LE, 4 cylinder with 100K miles on it.
Yesterday, I opened the hood of the car, and I noticed that there is hardly any coolant left in the reservoir. And I saw the coolant leak right below the starter motor. The coolant (pink color) seems to have been leaking for a while.
Does any one know what is that component that is sitting below that starter motor that is causing the coolant leak? And how to fix it?
thanks!
bavula is offline   Reply With Quote
Old 04-17-2007, 06:58 PM   #2 (permalink)
View toyomoho's Photo Gallery
Suggest you look above the starter for leaks, do this with engine warm so the coolant system is pressured. The coolant is most likely dripping down and ending up under the starter. Perhaps a hose clamp is leaking. Keep in mind there are many hoses with coolant hoses, radiator, cabin heater, oil cooler, manifold heater.
Coolant leak under the exhaust manifold! Help! xfreemanx Archived Corolla threads 4 05-12-2006 09:06 PM
Coolant leak from 1990 Camry tracyf 1st & 2nd Generation (1983–1986 & 1987-1991) 5 03-28-2006 08:24 AM
Brand of Coolant stir_fry_boy Camry & Solara Lounge 51 01-12-2006 10:45 AM
1993 5-speed Coolant leak Alaxy Galaxy Tercel, Paseo, Starlet, and Sera Forum 16 10-12-2005 09:36 PM
Coolant leak pdrover Archived Corolla threads 2 10-09-2005 12:29 AM
