Brake pads - Raybestos? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2007, 12:53 PM   #1 (permalink)
Tecumseh's Avatar
View Tecumseh's Photo Gallery
3rd Generation Brake pads - Raybestos?
Previous owner of Camry mounted squeaky pads and I have to replace it. What do you think guys of Raybestos ceramic products? Anyone using it? What are your preferences, recommendations? I read ceramic pads are very quiet, last longer, do not generate noticable dust and brake better.
My primary question is which brake pads type fits my auto. When I choose Toyota Camry 1995 on Raybestos website it seems I need PGD476 (front V6) and when I choose Toyota Camry 1996 it seems I need PGD697 (front V6). The problem is the date of manufacture of my car is 09/1995, however model year 1996 (VIN says so). If anyone knows which pads will fit please help.
Toyota Camry, 1996, 1MZ-FE, 4T1BF12K2TU118104
Tecumseh is offline   Reply With Quote
Old 04-18-2007, 01:29 PM   #2 (permalink)
View toyomoho's Photo Gallery
The car could be a 1996 made in 1995 to be on the market on 01/1996. Go to the Raybestos website and dig through to find brake pads (choose the car year range of 1995-1996). Pick you part number(s) then click on them to see the part dimensions and compare to what you have.
Old 04-18-2007, 01:39 PM   #3 (permalink)
Gameroom cash: $152705
View redgtxdi's Photo Gallery
FWIW, I'm not a fan of their "QS" (Quiet Stop) series.
Sounds like the greatest thing on earth, but I've cracked a couple sets of those already. Perhaps they've changed the blend to improve that possibility, but I didn't like 'em.
I like either OEM (you won't get any quieter than OEM if you're looking for quiet) or a brand from Autozone called "Pinnacle" (It's typically their most expensive pads, but you won't see the name Pinnacle anywhere. It's *not* part of their Duralast line, nor that Beck Arnley stuff. It's Carbon Metallic and they are simply the best pads I've EVARRRR used. They grab like there's no tomorrow and tolerate heat amazingly well.
redgtxdi is offline   Reply With Quote
Old 04-18-2007, 01:53 PM   #4 (permalink)
Tecumseh's Avatar
3rd Generation
Thanks. I will avoid QS.
I would have to visit my mechanic to check the size and fitment, so maybe someone just knows it and share the knowledge.
Old 04-18-2007, 01:58 PM   #5 (permalink)
If you go OEM, get the shim kit if you don't already have them installed. Helps keep then brakes quiet.
Old 04-18-2007, 09:18 PM   #6 (permalink)
Member
View triggerhappy007's Photo Gallery
I'm using the PGD562C (PG Plus Premium Ceramic) fronts for my 97 and it seems worse than the OEM pads. It's quiet and there is some brake dust. I'd stay away from Raybestos now. If you search around, people have good experiences with Akebono, Hawk, etc.
triggerhappy007 is offline   Reply With Quote
Old 04-19-2007, 01:35 AM   #7 (permalink)
Tecumseh's Avatar
3rd Generation
So I switch to Akebono. They are expensive though.
Old 04-19-2007, 07:33 PM   #8 (permalink)
mr.pringles's Avatar
View mr.pringles's Photo Gallery
how about brembo's?
mr.pringles is offline   Reply With Quote
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
Yup, Brake Pads nodrogkam Camry & Solara Lounge 15 01-03-2006 02:09 PM
Can't find replacement brake pads for XRunner kpagel 2nd Generation (2005+) 6 12-11-2005 04:49 PM
SW20 brakes for the do-it-yourselfer ... KAOS MR2 Forum 11 09-18-2004 01:21 AM
Changing brake pads on 94 Camry JohnCWms27 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-18-2003 10:20 PM
