Color matching my grill... opinions and input. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2007, 09:39 PM   #1 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Cool Color matching my grill... opinions and input.
This is just to see how many of you would think that me color matching my grill would look ok. I'm just trying to get a feel for the looks/possible downsides and what they would be. Here's what I plan to do.
-Cut out the vertical supports so it's just the 2 horizontal bars + toyota emblem.
-Sand the whole darn thing so the paint will adhere
-Apply 3-4-5 coats of DupliColor Cashmere Beige spraypaint
-Let dry
-Apply lots of clearcoat.
-Wetsand
-Stare in awe
The question is...
What grit sandpaper should I use before I paint and for the wetsand?
Thanks for all your input guys!!!
BlueFusion6851 is offline   Reply With Quote
Old 04-18-2007, 09:49 PM   #2 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
I would stay away from really low grit sandpaper, something like 200 should be plenty to rough it up for paint, then Id get up to about 1000 for the wetsanding. It should come out fine, if not it is pretty easy to find a used grille for dirt cheap. I say go for it, good luck!
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 04-18-2007, 11:07 PM   #3 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
If possible, bake the paint dry in an oven. It will cure to a hard strong finish.
Otherwise, you'll have chips in no time - been there done that. Of course, it would take a large oven to put a front grille in. Even heat lamps would help.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now   Reply With Quote
Old 04-18-2007, 11:16 PM   #4 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
View CJ Otey's Photo Gallery
^wouldn't the grill melt in an oven
I would use 320 grit on the grill and then put a couple coats of primer to fill in the imperfections and give the paint a smoother finish and i would use 2500 to wet sand
Two Toned 97 camry w/gen 4.5 front end conversion and 20" wheels and 2 Alpine Type R 15's in a vented box pushed by kicker zx1000.1
CJ Otey is offline   Reply With Quote
Old 04-19-2007, 12:00 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
depending on the temprature it would be fine. but ud want to suspend it somehow, good luck with that. id use 350-600 grit to start out with and then work finer and finer. DONT FORGET to use adhesive promotor. u NEED to use it if ur painting plastic with color match automotive paint and primer if u want the paint to last. sand, alcohol prep-wipe, adhesive promotor(spray), primer, sand, primer, sand, clean, color. thats what id do.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-19-2007, 12:30 AM   #6 (permalink)
93 240sx SR Hatch
DAMON's Avatar
if you sand and prime it and all that good stuff you dont need to bake it, mine lasted three years with no chips...
Old 04-19-2007, 07:00 PM   #7 (permalink)
How hard can it be?
Cool
Thanks! I'll go with the prime/sand method as I want this to be as cost effective as possible.
Opinions on 18" rims for 2006 Avy sunny_8 3rd Generation (2005-2012) 5 04-10-2007 07:22 PM
Kumho Road Venture AT 825 - opinions? thoughthard General Discussion 0 08-02-2006 09:23 PM
Opinions Needed! glassfinish 4Runner Lounge 2 07-21-2006 12:03 PM
turbocharging a 3vz-fe?!?!?! opinions, ideas and input needed. heyzeus2003 Camry & Solara Lounge 8 04-21-2006 12:02 PM
