Tranny Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2007, 12:33 AM   #1 (permalink)
View 1moreguy's Photo Gallery
3rd Generation Tranny Problem
Hi,
I have a 1993 Camry V6 with a Automatic Tranny, It will not shift into 2nd until the fluid is warmed up. There's nothing wrong with my fluid since it was replaced recently.
Could it be a faulty Torque Converter/sensor?
Thanks,
1moreguy is offline   Reply With Quote
Old 04-19-2007, 12:41 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
it may be a fualty valve body or spring, the tq converter prolly isnt the culprit.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-19-2007, 10:17 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
have you checked the fluid level to make sure it was filled with the proper amount. reason being the fluid rises when hot and may rise enough to shift the gears, but not when its cold.
Old 04-19-2007, 10:31 PM   #4 (permalink)
Will do, Thanks Guys
Old 04-20-2007, 11:35 AM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Is this car new to you? I notice you're in Canada where it's still cold.
It's normal for your pre'94 transmission not to shift until the coolant temp reaches 35 degrees C.
If this is not the case and the trans was power flushed, then you may have a some residual crud causing a sticking solenoid, etc..
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 04-20-2007, 05:58 PM   #6 (permalink)
No, I've had it for 7 years. Never had a problem with the Tranny before. The problem started only a few months ago. I'm gonna add more fluid and see what happens.
Tranny Problem? Help me out Please Dukmisser 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-23-2006 05:48 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
1986.5 Auto tranny problem CiDirkona Supra Forum 0 07-22-2004 06:02 PM
Problem w/ OD on tranny swap turbocamry Archived Corolla threads 11 06-15-2004 08:14 PM
