Car Going to hell again? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2007, 11:36 PM   #1 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Ok so I moved my battery to my trunk today so the other one in the trunk would have some company....
After I checked my wiring and stuff everything was good to go. Secured the battery terminals, car started in one shot
NOW... I can feel the car vibrating a little more than it normally does... Then I'm listening to the exhaust and its making like this chugging noise... like Chug chug chug...
When I put the car into drive it starts to shake or vibrate more! same for reverse....
Did I screw something up while i was wiring??
Curry is offline   Reply With Quote
Old 04-19-2007, 11:40 PM   #2 (permalink)
mr.pringles's Avatar
View mr.pringles's Photo Gallery
i dont know about the battery thing but my car idles rough, timing is fine and my exhaust has that "chug" sound too where my muffler moves up and down...
mr.pringles is offline   Reply With Quote
Old 04-19-2007, 11:48 PM   #3 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Unless you touched any ingnition wiring there is no way you could have made it idle rough because of the battery being relocated. Clean your TB, get some plugs, and auto tranny's like to play that little game of vibrating like hell. Mounts?
MIC0417 is offline   Reply With Quote
Old 04-19-2007, 11:54 PM   #4 (permalink)
Curry's Avatar
I doubt i touched any wiring but hey who knows. Im going to check again tomorrow and see whats up.
The mounts are new...
I have some new plugs, Im gonna put them in this weekend.
I was also told that my muffler is bad by the shop when i went for inspection about 2 months ago... but I was trying to remmeber if it was chugging before...
But the vibrating is new... wasnt doing it yesterday thats for sure.
Old 04-20-2007, 12:07 AM   #5 (permalink)
Odaiba Romance
shingouki808's Avatar
iTrader Score: 8 reviews
View shingouki808's Photo Gallery
3rd Generation
Check your wiring one more time. This time look specifically for grounding faults in the line. A bad ground somewhere might cause a retard in your ignition timing. Just a random thought. Good Luck.
アクション カメン 只今 さんじょう!!! ブリ ブリ ブリ。。。。。。。。。。。。
shingouki808 is offline   Reply With Quote
Old 04-20-2007, 12:16 AM   #6 (permalink)
Curry's Avatar
I had a feeling it could be the ground. Im gonna clean the spot and upgrade the wire.
Both batteries are grounded correctly. I have a total of 3 grounds alltogether
Just that one ground from the block to the chasis i think may be it...
And each battery is grounded to chasis
This is the ground from the block to the chasis
Old 04-20-2007, 04:13 AM   #7 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
u sure u didnt drill a hole thru something else?
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 04-20-2007, 09:21 AM   #8 (permalink)
John
View MemphisR's Photo Gallery
what gauge wire did you use for your positive and your ground?
2000 Toyota Camry I4 2.2L (Super White II) - Garage Monster!
2002 Chevrolet Silverado V8 5.3L (Pewter) - Daily Driver
MemphisR is offline   Reply With Quote
Old 04-20-2007, 10:46 AM   #9 (permalink)
Curry's Avatar
venom: pretty sure i didnt drill thru anything.
memphis: From the block to chasis im using the stock wire with a stinger terminal
Each battery is linked with 0 gauge wire and their grounds are 0 gauge as well.
Edit: Thats the stock grounding point btw up in the picture.
Old 04-20-2007, 12:41 PM   #10 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
dont know if u did but make sure the guage wire is larger then stock to compensate for the extra distance.
this sounds like an ignition problem which wouldnt have much to do with the batteries if its starting well. id check the sparkplugs and run some tests to see if any are miss fireing to rule that out as a possiblility.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-20-2007, 01:09 PM   #11 (permalink)
Curry's Avatar
Does the motor ground need to be on the battery? Cause i have it grounded to the chasis
Otherwise I will need to clean that spot fom the chasis to the motor and see if that works
I have 0 guage going fromthe alt to the battery in the back and 0 gauge between the batteries and everything else is 4 gauge.
Old 04-20-2007, 01:11 PM   #12 (permalink)
I HAS BOOST!!!
bigbird's Avatar
its recomended but i doenst have to be as long as the ground is good.
R.I.P.
Car Domain:
Old 04-20-2007, 01:18 PM   #13 (permalink)
John
ahh i see . . . id have to say try a new ground and see how that works out for you,
on my sound system i tried to ghetto rig an 8 gauge ground with a 4 gauge lead cable and kept having trouble with it thats why i ask
sorry i couldnt be more help i hope you figure it out bro
Old 04-20-2007, 03:23 PM   #14 (permalink)
Curry's Avatar
Yea im gonna swap the wire and re-sand the area so its nice and clean. I hope thats the problem.
Old 04-21-2007, 11:34 AM   #15 (permalink)
Curry's Avatar
Ok I just finished upgrading the grounds. It was actually two i upgraded. One of the batteries I changed to a 0 gauge and the ground up front which is actually for the tranny I changed to a 4 gauge ground.
It still has the problem.
The idle is at a normal speed. You dont really feel the vibration.
When you shift into drive and give it a little gas and let off thats when it starts to shake ALOT
I have 4 gauge wiring going from the fuse box and back and then I have another 4 gauge that goes from the starter I think all the way back to the batteries.
Any ideas ? I still dont know why its acting up...
