is my camry dying? help please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2007, 12:22 PM   #1 (permalink)
View 96camrey's Photo Gallery
hello, i have an 96 camrey with 129K. my car seems to be turning off at red lights or stop signs. it takes about 4-5 cranks to get it back on. i have changed all the fluids in the car, new belts, sparkplugs, distubter N cap, and wires. still no help im not throwing any codes i just cant figure out wth is wrong with my car. could anybody help me out maybe had a simular problem. only thing i can think of s a clogged gas feed line? which is why it might be turning off since fuel might not be gettng thier?
96camrey is offline   Reply With Quote
Old 04-20-2007, 12:36 PM   #2 (permalink)
View popeye08's Photo Gallery
It mostly like IAC valve problem, just search how to clean it, tons of posts.
popeye08 is offline   Reply With Quote
Old 04-20-2007, 12:36 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
possibly a bad fuel pump, have u tried cleaning out the throttle body? is the car hard to start when cold or does it just die when stopping?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-20-2007, 04:06 PM   #4 (permalink)
i go both ways-mac and PC
ghettosled's Avatar
Gameroom cash: $128595
does your car stall if you rev the motor and hold it for a couple of seconds? if not, then its not the fuel filter or clogged fuel line because the motor is drawing more fuel at the higher rpm. since its stalling at the low rpm, i agree with popeye and say its the IAC. might as well clean the throttle body as well while youre at it. this is a cheap and relatively easy fix-it.
Old 04-20-2007, 04:22 PM   #5 (permalink)
Gameroom cash: $275055
Clean the throttle, body paying particular attention to the square or diamond shaped port in the base of the throttle body. That's the passage leading to your idle air control valve. Spray the cleaner liberally down that port and let it soak a bit while you go on to clean the rest of the throttle body.
Mike
Old 04-21-2007, 12:14 AM   #6 (permalink)
Some mornings its hard to start up on 1st crank but not every say maybe 2 days out the 7 day, the throttle was clean at 90K by dealer. but I will search and clean it again myself. if I rev the motor car does not stall. only when I come to stops at lights it idles real low then just cuts off, takes about 5-7 cranks to start back up. i will check this IAC thanks a lot for the help. will keep you updated
Old 04-21-2007, 12:20 AM   #7 (permalink)
this is what i should do correct?
http://www.toyotanation.com/forum/t158097.html
Old 04-21-2007, 01:16 PM   #8 (permalink)
Correct.
Mike
Old 04-21-2007, 06:19 PM   #9 (permalink)
View marc780's Photo Gallery
Thats the basic how to. Give it a try before attempting anything harder, i have seen several cases where cleaning the TBI fixed a stalling issue.
If the IAC is the cause of the problem, you will/must notice SOME improvement in the stalling issue after doing this or the problem may be elsewhere.
If you cleaning the tb per the post, and notice some improvement but the problem is still there occasionally - remove the IAC for a more thorough cleaning and reinstall. If still no joy, the IAC may need to be replaced...but at only 129,000 i dont think thats too likely. Note that your IAC may or may not look like the one in the images.
Old 04-21-2007, 06:24 PM   #10 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
i have the same problem, i usually have to rev the engine
WhiteRabbit is offline   Reply With Quote
96 camrey engine light code PO441 96camrey 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-28-2005 12:53 PM
96 camrey probles help 96camrey 3rd & 4th Generation (1992–1996 & 1997–2001) 1 07-24-2005 12:51 AM
96 camrey check engine light on 96camrey Celica Forum 0 07-23-2005 11:35 PM
popes dieing Peter Off Topic 35 04-03-2005 07:44 PM
