Best oil for camrys ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2007, 11:23 AM   #1 (permalink)
Camry XLE V6 98
dbkevindb's Avatar
View dbkevindb's Photo Gallery
I alway use use catrol gtx, what you guys use ?
dbkevindb is offline   Reply With Quote
Old 04-21-2007, 05:57 PM   #2 (permalink)
Embrace the Suck
Edmo83's Avatar
iTrader Score: 8 reviews
View Edmo83's Photo Gallery
Mobil One Synthertic 5w-30, with matching Mobil one high efficiency oil filter., i usually change it out at 4500-5000 miles since i drive rather hard.
92 SC300 Garnet Red 5-speed 119k
01 Camry LE V6 Sailfin Blue 95K miles
Edmo83 is offline   Reply With Quote
Old 04-21-2007, 06:05 PM   #3 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
Oil
Mobil 1 10W-30 Extended Protection 15k changed at 10k OCI with Mobil 1 Synthetic filter.
JMSinMD is offline   Reply With Quote
Old 04-21-2007, 06:13 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Best oil...there really isn't a best oil. Most major brand oils will last at least 3000 to 5000 miles. Even Chevron Supreme and Wal-Mart Super Tech will work for 3000 miles.
Use what you like.
I've used Castrol GTX, Castrol Syntec Blend, Mobil Clean 5000 and 7500, Mobil 1 Super Syn and Tri-Syn, and Chevron Supreme,
2007 Camry 2.4L 5M
Old 04-21-2007, 10:10 PM   #5 (permalink)
Heat's Avatar
View Heat's Photo Gallery
Originally Posted by JJJJJJ
Synthetic is not required or recommended by Toyota engineers.
I used to work in Toyota engineering...
Very interesting information in your post. I'll be using Castrol GTX when I change the oil on my '95 LE.
While we're on the oil changing topic, what filters do people recommend and where to buy? How are the Toyota OEM filters? Any good place online to buy a case (ten?) at discount? Are new crush washers recommended each oil change for the oil pan drain plug?
For what it's worth I'm new to Toyotas, a relative just gave me her '95 Camry LE with 150,000 miles. I currently have a '99 Honda Accord LX and a '93 Volvo 940 wagon, which I'll probably be selling in the near future. I use Castrol GTX and Honda OEM filters on the Accord and Mobil 1 with Mann filters (high quality Volvo filter) on the 940.
Heat is offline   Reply With Quote
Old 04-21-2007, 10:11 PM   #6 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
Olive is good!!!
-SCWEET1- is offline   Reply With Quote
Old 04-21-2007, 10:13 PM   #7 (permalink)
I generally use Napa Gold which is a rebranded Wix filter or Purolator Pure One.
2007 Camry 2.4L 5M
Old 04-22-2007, 01:29 AM   #8 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Castrol GTX 5W-30.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now   Reply With Quote
Old 04-22-2007, 01:33 AM   #9 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
Castrol SyntecBlend 10W-30 every 3-4K
nodrogkam is offline   Reply With Quote
Old 04-22-2007, 09:51 AM   #10 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
RichieRichJP is offline   Reply With Quote
Old 04-22-2007, 10:11 AM   #11 (permalink)
on full afterburner
Gameroom cash: $1338197
I was using Castrol GTX before and just switched over to Mobil 1 High Mileage.
Old 04-22-2007, 03:19 PM   #12 (permalink)
View hassanbigboss's Photo Gallery
I use Mobil 1 Fully Synthetic with either Purolator PureOne or Mobil 1 oil filter....most dino and synthetic oils are fine....I have tried many oils in several different cars over the years and oils such as Mobil1, Castrol GTX, Castrol Syntec Blend, and Castrol Fully Synthetic Oil works just fine. I think that all of us as car enthusiast want the best protection for our car...which is totally understandable....but all these high quality oils that you guys have mentioned will do just fine....I mean...I have yet to see someone dino a car with different oils and see the HP difference....I mean...will there be a HP difference between a synthetic and a Dino oil....sure....but it will be very slight and will only start to occur after 3-4 k miles...which is the age after which a dino oil starts to loose it effectiveness....on the other hand....fully synthetic oil dont even start to show their true colors until the above mentioned mileage....but the bottom line is....most high quality oils let it be dino or synthetic will be just A OKAY...for your cars....unless you want to do 10 K mile Oil Change Intervals than just stick with synthetics....anyhow...thats just my 2 cents.
hassanbigboss is offline   Reply With Quote
Old 04-22-2007, 03:55 PM   #13 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
3rd Generation
Mobil 1 Tri-Synthetic 5w30 or 10w30, depending on the season.
Chevron Supreme 5w30 when I'm tight on cash.
TheKevin is offline   Reply With Quote
Old 04-22-2007, 04:00 PM   #14 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Vavoline High Mileage or Castrol High Mileage... I change the oil every 3 months, and use 5w30 during fall and winter, and use 10w30 during the spring and summer.
BlueFusion6851 is offline   Reply With Quote
Old 04-22-2007, 04:00 PM   #15 (permalink)
Where are you getting Mobil 1 Try-Syn? I haven't see that in stores since... 2002 or 2003.
2007 Camry 2.4L 5M
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 09:01 PM
1MZFE engine sludge issue-help okanetoys General Discussion 9 08-06-2006 01:16 AM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 12:36 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 12:04 PM
