In tanks fuel filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2007, 12:02 AM   #1 (permalink)
View johnko's Photo Gallery
Australia In tanks fuel filter
I have the late model 2000 Camry and the maintenance schedule tells me it's time to change the in tank fuel filter. Where do I access it? Any tips greatly appreciated.
Thanks
johnko is offline   Reply With Quote
Old 04-22-2007, 12:36 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
If it's a 2000 model, the pump, and probably the filter too, will be right under the back seat cushion. Just pull the cushion up to remove it.
The only fuel filter that I've ever changed is the one under the air intake box though.
2007 Camry 2.4L 5M
Old 04-22-2007, 02:31 AM   #3 (permalink)
Thanks for the reply. I have spoken with a mechanic who said the more you run your fuel tank low then the more reason to change the in tank fuel filter.
Old 04-22-2007, 06:49 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
ive NEVER changed that filter on any car- even when i had my 23-year-old suburban. did you have debris fall into your tank?
its strange your mechanic told you to change it especially if you run your tank low more often - this is the first time i heard this. the fuel is pulled from the bottom of the tank so it shouldnt matter what the fuel level is. are you sure you it wasnt the fuel filter that should be changed?
Old 04-22-2007, 11:46 AM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
NO NEED TO CHANGE THE SOCK OR STRAINER IN TANK FILTERS UNLESS YOU HAVE FUEL PUMP ISSUES!
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 04-22-2007, 11:50 AM   #6 (permalink)
There's no scheduled time interval for the inline filter either. It's not a bad idea to change it every 2 years or 30,000 miles, especially if you use fuel system cleaners.
Old 04-22-2007, 11:51 AM   #7 (permalink)
Old 04-23-2007, 04:11 AM   #8 (permalink)
Thanks one and all. I will take the advise and leave the in tank filter alone.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
For Sale Brand New Camry Hybird for just $19000 cars01 Camry Hybrid 1 04-07-2007 06:00 PM
Fuel pump and Fuel filter secaII4884 89-95 Toyota Pickup/Hilux 2 03-06-2007 11:10 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
Fuel Filter Replacement xtremekuruption Camry & Solara Lounge 5 06-05-2005 09:35 PM
