Rubber or Polyurethane? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2007, 09:48 PM   #1 (permalink)
View Lighty's Photo Gallery
Post Rubber or Polyurethane?
I'm looking to change my bushings soon as i am getting ready to change my stock susp. setup to a H&R/Tokico combo. Right now, my cam-dawg has 146K miles and on bad roads, I get alot of road noise which I hate. Will the new suspension compensate(meaning stay the same) for the noisy polyurethane? Or will it be even noisier?
Lighty is offline   Reply With Quote
Old 04-22-2007, 11:15 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
well if ur changing to performance suspension then ur gonna hear the road even more anyways. ud want Polyurethane to improve performance, not to lessen road noise, Polyurethane are actually kinda squeeky. if u want less road noise then go and dynomat the car, that stuff works wonders.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-22-2007, 11:38 PM   #3 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Use white lithium grease prodigiously and try some teflon tape to reduce the squeakiness when installing bushings.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 04-23-2007, 12:02 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
polyeurathane will be noisier, but perform better.
and i just grease mine and never had a problem with the squeek.
Old 04-23-2007, 12:33 PM   #5 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
dam thats alot of teflon...!
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 04-23-2007, 05:57 PM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Poly set with 3M Window Weld poly.
Hit the bushings with sand paper to roughen it up so it retains more grease.
Drill & tap both the bugshings and brackets themselves so you can install a grease fitting for easy re-lubrication.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 04-24-2007, 07:57 AM   #7 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
the hole of the bushing can be roughened with a large bolt threaded in to cut some grooves.
Use push in type zerk fittings. I will be doing this soon.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-24-2007, 10:37 AM   #8 (permalink)
on full afterburner
Gameroom cash: $1338197
What type of grease do you guys use?
How often do you have to regrease your bushings?
Burning Rubber Odor Roger R. 5th & 6th Generation (2002-2006 & 2007-2011) 5 03-23-2007 04:56 PM
Help with Strut Mount rubber separation? yipal 3rd & 4th Generation (1992–1996 & 1997–2001) 2 10-22-2006 08:26 PM
Update: polyurethane motor mounts done [pics] Ratko Camry & Solara Lounge 51 12-15-2005 06:38 PM
