5sfte update
So today, i finished plugging in all of the connectors on the 5sfte ran into a couple problems though, the way i setup my oil pressure switch it is pointing straight up so i had to extend the wire for the connector and plug that in. I lost the papers for my FPR so i dont know which nipple is in and which is out. so i could not hook up any fuel really And my last problem is the vacuum hoses. I tried the best i could trying to figure all the hoses out but... I dont know if anybody has a diagram for it that would be great. Other than those few things, I filled the tranny with royal purple, and hooked up the linkages up to it, clipped them in. put the axles in, filled the engine with oil, i still have one connector i dont know where it goes, and i need to bolt in the powersteering line. Get the fuel figured out and i should be able to actually start it. I turned it over, doesnt sound like its going to fall apart. so it should be fine. If anybody has a wiring diagram and vacuum diagram that would help me ALOT.
