Usually right on the back of the box of spark plugs it tells you what torque, or how much of a turn past finger tight to tighten. There are usually two different types, with and without washers. I believe all of the ones made for your car are going to have washers on the spark plug. Because the washer smashes a little with you tighten the spark plug, the amount it is turned will always be more. The turn method works good, you don't need a torque wrench.
Also, as mentioned about having a hard time getting the plugs out. What is a must to make them come out good the next time, is to use anti-sieze. You can get this in little one time packs right at the automotive store. Or if you plan on using more, you can get it by the tube, or can. I use it on every thing I take apart, except for wheel lug nuts. When I put something back together I have it on there, it lubes the threads, and will make it easier to get off the next time. Plus something like spark plugs, which are steel, and the head on your car which is aluminum. Dissimilar metals corrode against each other, and there is a lot of heat on the spark plugs which is hard on the thread joint between the plug and head. Remeber when using anti-sieze, a little goes a long way. You just need to put a little on the tip of your finger and put a dab on the threads. You don't even need to coat it all the way around, it will definetly work its way in, as you thread it in. Be careful what you get it on, it is slimy and gets everywhere. Sounds like this is your first time getting into something like this. Read all instructions, and apply common sense, put it back together the way it came apart. And if there is multiple of something do one at a time, in case you forget how to get it back together, you still have an assembled one to use as an example. You will do fine!
