how to spot a vacuum leak?....help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2007, 05:44 AM   #1 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
Okay, so the whole idle situation IS a vacuum leak, I am convinced of this. The plugs have been changed out, new gas has been added (burned the old stuff off), and the exhaust has no leaks anywhere on it. which leads me to agree that it is a vacuum leak, only I don't know where or what to look for (I admit on that part of a car I am a N00b) any help or ideas would be great....thanks
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 04-25-2007, 06:24 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Use WD-40 or carb cleaner to spray around gaskets, etc. and listen for increase in idle rpm. Also could use a length of vacuum hose - one end in your ear the other poked around the vac hoses. Maybe a mechanics stethescope, but I have found those too sensitive. For vac leaks I take the probe off and use a bit of vac hose in its place. For tough to find leaks you could take it to a shop with a smoke machine.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 04-25-2007, 02:41 PM   #3 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
How about those cans of smoke used to test fire alarms?
Dave's is offline   Reply With Quote
Old 04-25-2007, 03:32 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
use a can of throttlebody cleaner and spray it around all your hoses, etc....if the engine revs, then you have a vacuum leak
from the sounds of the way your engine is running, it sounds like a pretty massive one too, so check all hoses first (for ones disconnected) after that, check your big/common gaskets- throttlebody, intake plenum, egr, etc.
HaHa
Old 04-25-2007, 06:46 PM   #5 (permalink)
Gameroom cash: $924000
View ASG14's Photo Gallery
didn't you have that issue King???
5 Lug Corolla WHAT?
vacuum leak hellonwheels Pre-88 Toyota Pickup/Hilux 4 01-01-2007 11:08 PM
98 Corolla Vacuum Leak jaykirs Archived Corolla threads 0 03-18-2006 04:54 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
Vacuum leak, How to find? speedyts49 Celica Forum 13 09-24-2005 01:53 PM
