Anyone know how to bench bleed a master cylinder? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2007, 08:47 PM   #1 (permalink)
View newbie212's Photo Gallery
I just ordered a master cylinder for my 97 XLE. Was told that I needed to bench bleed it.. Anyone have any tips on how to do this? I have a vice and was told that I need to use a plunger or something to force the piston inside.... I get lost after that point... Any help would be appreciated.. Thanks
newbie212 is offline   Reply With Quote
Old 04-25-2007, 09:08 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
ok first of all let me say ive only done this on a very old master cylinder from 1972. that being said, i clamped it down first to assure it wont move. next i sealed up one of the 2 brake line ports. then i filled it up with fluid and secured the cap. finally i just used a round tiped crow bar to push on the pistion that leads the the break booster. DO NOT let the resivor go dry or ur spinning ur wheels so to speak. after my front brake line port and pluming was done i switched, again im not sure how many ports the camry cylinder has. thats how i did it and it worked very well for me on that paricular car, id imagine it would be about the same on the camry.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-25-2007, 09:35 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check the link below for details.
http://www.toyotanation.com/forum/t168404.html
Old 04-26-2007, 02:00 PM   #4 (permalink)
Gameroom cash: $303055
To add to the link toyomoho referenced, you must push the piston in slowly. You do not want to create more air bubbles by pushing it in too rapidly.
Mike
Old 04-26-2007, 02:18 PM   #5 (permalink)
View hooRAH's Photo Gallery
To bench bleed the brake master, you want to get the fluid going through the system (and the air out) before putting it in the car. You will want a way to route the air bubbles and fluid out of the exit ports back into the resivoir (or into a container).
You can put the MC in a vice, open the ports (slightly), and pump the piston slowly until all fluid and no air comes out. Then put the MC in the car. You will still have to bleed the brakes after putting the MC in the car.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
