96 Camry Major Tune up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2007, 12:41 AM   #1 (permalink)
View bakakuso2's Photo Gallery
3rd Generation 96 Camry Major Tune up
i have no idea what i need to do.
Can someone give me a list and what can actually be done without a mechanic? Thanks
bakakuso2 is offline   Reply With Quote
Old 04-27-2007, 06:07 AM   #2 (permalink)
View jmp0126's Photo Gallery
How many miles do you have and what engine?
jmp0126 is offline   Reply With Quote
Old 04-27-2007, 06:07 AM   #3 (permalink)
Old 04-27-2007, 11:30 AM   #4 (permalink)
2.2 liter 4-cylinder
147k miles.
Old 04-28-2007, 10:35 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
timing belt
tensioner
waterpump
replace all seals and gaskets
flush tranny, coolant and oil
clean and inspect intake system(TB, intake manifold and whatever else)
sparkplugs
replace thermostat
plug wires(cant remember if the 96 has a distributor)
inspect ignition system
if u really want to get down and dirty then replace the piston rings too(lots of work)
i prolly forgot somthing but im sure someone will come along and fill in the blanks.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-28-2007, 04:24 PM   #6 (permalink)
97 Camry
View Davee's Photo Gallery
Canada
Originally Posted by bigbird
timing belt
tensioner
waterpump
sparkplugs
replace thermostat
I am at 180,000 miles - have just done timing belt second time & water pump once Old water pump looked as good as new
Plugs should have been done once already on yours so maybe skip for a while
I have never changed plug wires & don't think it is worth it till a misfire. Check that thermostat is closed on cold start by holding a hose to rad unless t/s is toasted you will get very little heat to your hand - no big deal to change when it fails so wait
Forget the piston rings till you are burning significant oil. I agree with other stuff unless done already-- no performance increase out of most of the list
Davee is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
thinking bout buying a camry for my next car 96 up 4clyinder or v6 . cool car guy 3rd & 4th Generation (1992–1996 & 1997–2001) 20 04-30-2005 06:59 PM
Remote car starter for 96 Camry sourcerer 3rd & 4th Generation (1992–1996 & 1997–2001) 5 03-24-2005 10:29 PM
96 Camry side mirror sourcerer 3rd & 4th Generation (1992–1996 & 1997–2001) 2 04-12-2004 12:05 AM
idle solenoid control motor 96 camry rough starts. help? sigmachibri 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-25-2004 06:44 AM
