Can someone with a 3vz-fe do me a fav? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2007, 01:03 PM   #1 (permalink)
5sp 3VZ-FE
mescalito's Avatar
View mescalito's Photo Gallery
go outside and start your car
pop the hood and push down and/or wiggle the lower fuse box on the right hand side (the one thats connected to the fender and is the longest)
and then report back to me if your car stalls out or bogs while youre moving it around
if not, can someone tell me why mine would do that?
thanks!
oh hello btw, it's been a while
mescalito is offline   Reply With Quote
Old 04-27-2007, 01:26 PM   #2 (permalink)
engineer in training
Gameroom cash: $145055
Mine doesnt stall and its not even connected to the fender anymore.
Old 04-27-2007, 02:26 PM   #3 (permalink)
5sp 3VZ-FE
mescalito's Avatar
any ideas why it would cut out? It even does while driving, the car will just shut off
Old 04-27-2007, 05:10 PM   #4 (permalink)
do you loose all electrical power or just is just die? any CELs?
Old 04-27-2007, 05:27 PM   #5 (permalink)
5sp 3VZ-FE
mescalito's Avatar
nope, still get electrics and no CEL
the car literally clicks off - if i pop the hood and re-ground the fuse box it fires right up and runs like new
edit: just tore down the box and upon inspection the wire leading into a harness that plugs into the back of a fuse had pulled free - the jiggling of the box must of restored the connection temporarily.
it started to rain before we could put everything back together but hopefully this is the reason, it would seem that it would be the culprit and I will report back with my findings just in case someone else is having a similar problem
Old 04-27-2007, 09:10 PM   #6 (permalink)
In Tents
ToyCam187's Avatar
View ToyCam187's Photo Gallery
Do you notice anything else moving around?
Could be a bad ground somewhere else.
ToyCam187 is offline   Reply With Quote
Old 04-28-2007, 08:55 AM   #7 (permalink)
5sp 3VZ-FE
mescalito's Avatar
I am pretty sure the problem is solved, after a road-test yesterday it seems that loose wire was the cause of the random shut-offs
so if anyone else experiences a problem like that, this may be your solution!
1mz or 3vz - whats your favourite? v-cam 3rd & 4th Generation (1992–1996 & 1997–2001) 18 02-28-2007 08:02 PM
Is there demand for a 3.4L or 4.0L V6 swap kit? QuadCamSix Camry & Solara Lounge 67 08-16-2006 09:16 PM
5vz VS Rebuilt 3vz shoes1382006 89-95 Toyota Pickup/Hilux 4 06-30-2006 09:15 PM
92 3VZ FE Failed Emissions !!!!? scprandy 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-31-2006 10:51 AM
3VZ FE Head Removal scprandy Camry & Solara Lounge 5 01-16-2006 02:32 PM
