manual trans hard to shift in gears - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2007, 05:52 PM   #1 (permalink)
cardomain.com baggedcamry
BAGGEDCAMRY01's Avatar
View BAGGEDCAMRY01's Photo Gallery
3rd Generation manual trans hard to shift in gears
i notice when im driving the shifting is getting harder. and when im in the car at home with the engine off i put the shifter through the gears i notice the same thing. had the clutch checked its still good . i cant figure it. any pointers on this subject
BAGGEDCAMRY01 is offline   Reply With Quote
Old 04-27-2007, 06:17 PM   #2 (permalink)
Gameroom cash: $184355
View wuda pig's Photo Gallery
you can try to get the transmission checked. Maybe the gears are worn out?
wuda pig is offline   Reply With Quote
Old 04-27-2007, 06:50 PM   #3 (permalink)
97 Camry
View Davee's Photo Gallery
Canada
Lift the centre consol & lever boot. Lube the ball & rod joints with silicone grease . This helped me although I have always had trouble catching reverse. I also went to synthethic gear oil for improved performance in the cold-40! This also helped
Davee is offline   Reply With Quote
Old 04-27-2007, 07:14 PM   #4 (permalink)
would the adjusting shim lever have anything to do with it?
Old 04-29-2007, 07:38 AM   #5 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
shim lever??? like Davee said, a lot of times the shift linkage at shifter starts to stick. remove it and take apart what you can and lube each joint.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 04-29-2007, 08:09 AM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
I agree, it has to be oiled once in awhile....
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 04-29-2007, 01:59 PM   #7 (permalink)
thanks guys i have regreased it and bought a new shime everything slides smooth again
Old 04-29-2007, 03:26 PM   #8 (permalink)
mazdaverx7's Avatar
glad to hear you got it working again!!! happy motoring!
85 RX-7 GS 5spd
Old 04-29-2007, 07:08 PM   #9 (permalink)
Heat's Avatar
View Heat's Photo Gallery
Have you ever changed the manual transmission fluid?
Heat is offline   Reply With Quote
Old 04-29-2007, 10:47 PM   #10 (permalink)
yes i have i changed it twice this yr
Old 04-29-2007, 10:47 PM   #11 (permalink)
and all the
Old 04-29-2007, 10:48 PM   #12 (permalink)
fluids as well oil, brakeoil, steeringoil, antfreeze, clutch
Old 04-30-2007, 07:07 AM   #13 (permalink)
mazdaverx7's Avatar
as long as its working ok now, dont bother with teh fluid, as you know that it isnt your problem.
85 RX-7 GS 5spd
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
Adjusrtment shift cables Manual 4 cyl Davee Camry & Solara Lounge 5 02-11-2006 10:52 PM
Manual trans and diff fluid? voodoobike 2nd Generation (2005+) 3 02-07-2006 08:00 PM
For manual trans, engine braking or wheel brake? abimanyu Archived Corolla threads 17 10-23-2005 08:32 PM
