Ok, here's my first post...and problem..."Check Engine Light"
Model: Camry 1997, V6, California
DTC: P0135 "Heated oxygen sensor heater circuit malfunction (bank 1, sensor 1) (according to Auterra Dynoscan and Chilton's)
Possible problem area:
- Open or short in heating oxygen sensor heater circuit
- Heated oxygen sensor heater malfunction
- PCM malfunction
Diagnostic steps taken so far:
1. Unplugged negative battery terminal, MIL disappears, then reappears after ~10mi (done twice)...thus, it's a "true" DTC (right?)
2. Bought from Kragen online a Bosch Premium Oxygen Sensor (Part#13354) for $99. Checked the resistance between terminals +B and HT and it's 8.8ohms
Questions:
1. Are these the correct locations of each sensor?
- Bank 1, Sensor 1 = upstream (pre-catalytic), rear manifold sensor, near firewall [Picture A]
- Bank 1, Sensor 2 = downstream (post-catalytic), access from underneath car [Picture B]
- Bank 2, Sensor 1 = upstream (pre-catalytic), front manifold sensor, easily accessed under hood [Picture C]
[Picture A]: Bank 1, Sensor 1 ???
[Picture B]: Bank 1, Sensor 2 ???
[Picture C]: Bank 2, Sensor 1 ???
2. If Bank 1, Sensor 1 is near the firewall, how does one access this sensor? From underneath car? From passenger/driver seat through firewall? (I've taken some pictures from underneath the car and it's doesn't look easily accessed...)
3. Does the Bosch oxygen sensor resistance seem a bit low? (8.8ohms) Shouldn't it be higher? Would a Toyota OEM oxygen sensor have the "11-16ohm @68F" as specified by the factory service manual, and thus the higher price?
4. As an aside, what would happen if I replaced the "faulty" oxygen sensor with an air/fuel sensor instead of another oxygen sensor? Would the PCM understand?
Thanks!
