Broken Driver Side Window winder - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2007, 08:11 AM   #1 (permalink)
View Dijalnar's Photo Gallery
3rd Generation Broken Driver Side Window winder
Ok I have a 93 Camry with manual door winders.
Recently the winder stopped working and now the window just randomly slides down itself. I had to wedge some cardboard in to stop it dropping. I have pulled the interior and pulled out the box where the wires head to but i didn't pull the box apart as i didn't want to totally screw it without knowing what i was doing.
It seems that there is something not gripping when you try to wind up but it is ok when you wind down.
Does anyone know if this is repairable or whether the whole box needs to be replaced..
If you need to replace the whole box does anyone know how to do this as a th haines manual isn't very hlpful in this area.
Also does anyone know how much a winder set up costs if you can buy them. $AU?
thanks
Dijalnar is offline   Reply With Quote
Old 05-01-2007, 05:45 PM   #2 (permalink)
View toyomoho's Photo Gallery
The manual setup usually has a crank with a gear and a rack with teeth. Sometimes the teeth get damaged, something breaks. Find the service info at the link below. Replacement should not be difficult, might try junkyards for parts.
http://oregonstate.edu/~tongt/camry
Pass side auto down window switch dan1701z 1st Generation (1995.5–2004) 1 10-27-2006 10:08 PM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
