97 5SFE balance shaft bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2007, 07:59 PM   #1 (permalink)
View Albetime's Photo Gallery
3rd Generation 97 5SFE balance shaft bearings
Hello from a newby
I am rebuilding the engine on my 97 5SFE and needed to disassemble the balance shaft assembly for cleaning. Engine had 3 spun rod bearings and I would like to replace the balance shaft bearings while I have it apart.
Has anyone been able to locate these bearings?
I have tried my local Import auto parts stores, machine shops and the dealer without any success.
Also does anyone know the torque specification for the bolts on the assembly, not the mounting bolts they are in the Haynes manual?
The Haynes manual says not to disassemble this unit but it had to be done for cleaning.
Thanks for any help
Albetime is offline   Reply With Quote
Old 05-02-2007, 08:43 AM   #2 (permalink)
Turbo-D Junkie
View gumbydammit's Photo Gallery
Where are you in VA??
PM me, I might have an assembly with VERY low miles.
(Crash cracked the end of the crank, balancer un-touched.)
Shelties...a mans best friend
gumbydammit is offline   Reply With Quote
Old 04-15-2011, 06:10 PM   #3 (permalink)
View Marmmot2001's Photo Gallery
5sfe Balance shaft lash adjustment tool specs
If you are doing anything with the balance shaft assembly you will need to adjust for gear lash. Since I am rebuilding a 5sfe engine I dropped the $60 ( an absurd price for the thing) for the SST (09224-74010-01) to measure the lash. All the tool is, is a ruler with three marks on it and a loop that clamps on the end of one of the balance shafts. The ruler has three marks, 10.5, 7 and 3.5 cm from the center of the balance shaft which the tool is attached to. You are supposed measure the lash from the third (10.5 cm mark). So long as you measure the lash from 10.5 cm, you do not need the tool. My guess is that you can make one of these tools out of a collar clamp with a straight piece of something attached to it or anything that will clamp on to the end of the shaft and accurately measure 10.5 cm in radius
[IMG]file:///C:/Documents%20and%20Settings/Andrew%20Thomas/My%20Documents/My%20Pictures/Adobe/Digital%20Camera%20Photos/2011-04-15-1558-26/100_1113.jpg[/IMG] [IMG]file:///C:/Documents%20and%20Settings/Andrew%20Thomas/My%20Documents/My%20Pictures/Adobe/Digital%20Camera%20Photos/2011-04-15-1558-26/100_1113.jpg[/IMG]
Marmmot2001 is offline   Reply With Quote
Old 04-15-2011, 09:11 PM   #4 (permalink)
Gameroom cash: $106355
View Fortified Souls's Photo Gallery
Edit: opps sry for bumping a 4 yr thread followed the noob in here without looking at the time stamp lol
Fortified Souls is offline   Reply With Quote
engine break in and balance shaft questions bennington28 Hardcore Tech and Competition 6 05-11-2012 06:31 PM
RIPPMODS Second Stage of 5SFE Supercharger Modifications! Its built now! RIPPMODS 3rd & 4th Generation (1992–1996 & 1997–2001) 45 04-10-2008 11:20 AM
5sfe balance shaft question nateluv45 3rd & 4th Generation (1992–1996 & 1997–2001) 8 07-08-2004 04:37 PM
Balance shaft in a 7mge? Matt Long General Discussion 1 04-02-2004 06:23 AM
Balance shaft really needed in the 5S-FE? Meisner Hardcore Tech and Competition 8 04-12-2002 08:36 PM
