Fan Problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2007, 12:08 AM   #1 (permalink)
View fe519's Photo Gallery
Fan Problem...
Hey everyone, I got a 93 ES300 (same as a camry). I posted in the lexus section but no one is there to help me. Anyways, the car is overheating and I changed the t-stat but it still overheats. I tested the fan by turning on the AC, but it still doesnt come on. So I narrowed it down to the fan not cooling down the car. I was also looking for the relay or fuse for the fan but cant seem to find it. Can someone direct me to the right location of the fuse and relay? Lastly, should i be testing anyting else except these items? Thanks for the help.
fe519 is offline   Reply With Quote
Old 05-04-2007, 07:54 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Electric fan or hydraulic? Engine? If electric you can test fan motor by disconnecting plug and jumping directly to battery. There may be several relays, my Camry has 3 for fan circuit plus fuse. Could also be engine temperature switch. My switch is located on bottom of rad. To test switch, turn on ignition (no start) and disconnect plug to switch - fan should start.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-04-2007, 06:48 PM   #3 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
check your coolant and hoses too
toyotaholic is offline   Reply With Quote
My Electric Fan Mod is Complete! Pb 2nd Generation (2005+) 116 08-13-2009 11:34 PM
Cheap electric fan upgrade whiteytaco 1st Generation (1995.5–2004) 9 04-27-2007 11:50 AM
'96 Landcruiser Ignition Problem Zog Land Cruiser Forum 0 02-20-2006 10:03 PM
Engine cooling problem aldwinenriquez Archived Corolla threads 7 07-07-2005 07:47 AM
NEED HELP: Fan not working GetDFeelin Camry & Solara Lounge 2 09-15-2004 07:43 PM
