a few ?'s - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2007, 11:25 AM   #1 (permalink)
FROM V6 TO 4BANGER :(
playmategirl's Avatar
View playmategirl's Photo Gallery
3rd Generation a few ?'s
first off i have seen several different answers for this ? what is the factory hp rating on a 95 camry le v6 auto i have read both 200hp and 188hp whats the right answer? and also can you jumper the diagnostic plug for the camry using a paper clip in t1 and te1 or what is it? and where can i get the codes for it?
YES its fast.....NO you cant drive it!
My 95 Pink and Black 1MZ Camry.... Needs a new head...currently out of commission....
My new Camry...95 5SFE...Gold and Black...for now!!
playmategirl is offline   Reply With Quote
Old 05-05-2007, 11:32 AM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
188HP is the output for the Gen3 V6 with the 1MZ-FE engine, I believe the '92 and '93 had the 3VZ engine which was 185HP?
I have a complete list of OBDII troulbe codes on my PC. I got them from here but dont remember the thread.
geoff5093 is offline   Reply With Quote
Old 05-05-2007, 11:48 AM   #3 (permalink)
well according to my owners manual im pretty sure it says 200hp and when i try to search on the net there are some places that say 200 and some say 188. where can i get the trouble codes for mine cuz my check engine light is on.
Old 05-05-2007, 12:41 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
the 95 should be rated at 188hp since it is the first gen of 1mz's. 96 and up became something around 196hp and then a bit later it became 200hp. The torque remained about the same for all of them though. So long story short, they're all about the same speed really.
and you'll have to get an obdII scanner to read your codes. all the 1mz's starting from 94 were obdII compliant
HaHa
Old 05-05-2007, 12:44 PM   #5 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Yuo can't jump yours, it must be read by an OBD-II scanner. or scanner / logger. The anceillary systems were OBD-I leftovers, which is why you still have the related OBD-I equipment & diangostics on your 100% OBD-II drivetrain.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 05-05-2007, 01:29 PM   #6 (permalink)
so according to the graph above it is 200hp? when i took it to a local shop they said it was an obd1 but i found another plug behind the small change holder next to the fuses is this the obd2 plug?
Old 05-05-2007, 01:35 PM   #7 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
yes!
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 05-05-2007, 03:28 PM   #8 (permalink)
geoff5093's Avatar
Toys, why is it that your chart shows it's 200HP, while everything else on the web says it's 188HP?
Old 05-05-2007, 04:48 PM   #9 (permalink)
View Richard_97LE's Photo Gallery
it says the 1MZ-FE has been improved, showing the 1MZ-FE was previously 188HP, with this change boosted HP, as I recall Eye8Pussies said this happened in 96. Not to mention the Dyno was done with 96 grade fuel. In reality unless your running 91 grade or higher you won't have those numbers. Lets face it, on a 12 year old car, that has likely been using 87 grade most of it's life, you don't have 188HP in a 95 let alone 200HP. You won't get near that to the wheels, that is unless you have a new or fully rebuilt engine, trans., drivetrain. and even suspension. Now 188HP is respectable, I only point all this out because those numbers will not be accurate unless your both keeping excellent care of your car and running high grade fuels, both of which I recomend highly.
Richard_97LE is offline   Reply With Quote
Old 05-05-2007, 07:30 PM   #10 (permalink)
Gameroom cash: $924000
View ASG14's Photo Gallery
I swear Toys is like one of the only people left here that know what he is talking about.
playmate, yes, that IS in fact the OBD2 port. The black trapozoid.
geoff, read the chart, it says 188, then the later years were 200hp.
Richard, the test was done 91, not 96 octane rating. And the car will not drop an extreme amount with age, unless abused. My car almost always gets 87. That does not degrade the engine faster. My car gets the the crap beat out of it running 87 and almost at 100k miles, and does not seem to have any power loose.
5 Lug Corolla WHAT?
Old 05-05-2007, 09:32 PM   #11 (permalink)
sweet thanks.
Old 05-06-2007, 06:53 AM   #12 (permalink)
geoff5093's Avatar
Ah, gotcha, I was looking on the left side only.
Old 05-06-2007, 09:15 AM   #13 (permalink)
Toysrme's Avatar
Cool
It's 188.................................................. .................................................. ...............
1994-1996 Camry = 188bhp, 1997 = 192bhp in the Camry, 1995 Avalon = 192bhp, 1997 Avalon = 200bhp
Now with Turbo!
Old 05-10-2007, 08:27 PM   #14 (permalink)
look carefully, says 91 or higher, look 1 inch lower and you'll see where it states 96 octane was used for above specifications. Now if you choose to state virtually no one knows what they're talking about, you may as well group yourself into that catagory, reading is FUNdemental!
Old 05-10-2007, 08:49 PM   #15 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
If I remember right its a different reading as 96 octane rating is not the same as 96 we see on the gas stations for us or something like that, please can someone answer this.
felonyr301 is offline   Reply With Quote
TRD Exhaust ?'s Scottr23 2nd Generation (2005+) 11 04-02-2007 02:29 PM
So...who agree's that the Camry section has been flooded with retarded 07 ?'s Corollacrazy42 Off Topic 53 06-30-2006 11:53 PM
1995 Camry ?'s Bullitt44 3rd & 4th Generation (1992–1996 & 1997–2001) 2 11-01-2005 04:13 PM
some ?s black99 Solara 5 08-17-2005 02:57 PM
