4 cyl valve cover torque - 17 or 30 ft lbs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2007, 02:07 PM   #1 (permalink)
View 68Malibu's Photo Gallery
Changed my hard gasket on my 99 4 cyl after noticing some drips on the floor each night. Bought a Fel-pro, installed it and torqued nuts to 17 ft lbs in baby steps (about 4 steps until 17). Washed engine and everything was good for about two weeks, then small drops began to appear again. I re-torqued to about 25 ft lbs and all was good for 2-3 weeks, now it drips a tiny bit again (about a dime sized drop each night).
Those who have successfully replaced the gasket and not used sealer (per Fel-pro), what torque value did you use?
68Malibu is offline   Reply With Quote
Old 05-05-2007, 02:30 PM   #2 (permalink)
View toyomoho's Photo Gallery
Clean all sealing surfaces thoroughly then apply some kind of non-hardening gasket sealer. Torque up the nuts slowly until they hold 17ft-lbs consistently over time as the gasket seats.
Old 05-05-2007, 03:22 PM   #3 (permalink)
I have some very good sealer and would have used it here as I typically do on other cars but the Fel-pro instructions said not to in bold writing. Everything was very, very clean.
Old 05-05-2007, 09:15 PM   #4 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
Buy a service manual. There are spots where you should/need to include sealer. Do a search you might find a pic here somewhere......
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
Old 05-05-2007, 09:18 PM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
yeah, what alotawatts said. there are common leak points that even a new gasket has problems sealing. even though everything was very clean, did you use something like brake cleaner on the gasket mating surfaces?
Old 05-06-2007, 06:26 AM   #6 (permalink)
Oh yes, I used brake cleaner and got it spotless. I've successfully built several engines in the past so I'm pretty versed on gaskets. I should have followed my instincts and used a dab of sealer at the cam cap corners. I may take it back off and add a little sealer.
Thanks for the replys.
Re: Valve cover gasket set on 4AGE Kevs Toy Archived Corolla threads 4 01-17-2007 02:21 PM
best valve cover gaskets for '97 V-6 Robert K 3rd & 4th Generation (1992–1996 & 1997–2001) 9 01-05-2007 06:10 PM
A small mistake... need new valve covers east_stingray 89-95 Toyota Pickup/Hilux 6 12-02-2006 06:19 PM
Remove 3s-fe valve cover jay_wang2000 Camry & Solara Lounge 6 02-14-2004 12:02 AM
