Transmission oil fill? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2007, 08:44 PM   #1 (permalink)
View GreenGrimlin636's Photo Gallery
Lightbulb Transmission oil fill?
Drained the transmission oil and differential oil.
Filled the differential oil up, no prob... but
Where is the A/T oil fill on the 1995 2.2L 4cyl?
Is it the 14mm hollow-bolt with on the top rear of the tranny? It has a metal cover with a small spring and block off plate inside that fits over the top of the hollow-bolt.
I'm not to keen on trannys. Pretty good on everything else tho. lol. Never torn down a tranny. I guess that's why.
THANKS
GreenGrimlin636 is offline   Reply With Quote
Old 05-05-2007, 09:00 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
i believe that the fill is through the dipstick tube.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 05-05-2007, 09:22 PM   #3 (permalink)
Really? I mean that was gonna be my last resort, but I thought surely there was a fill on the side of the tranny some where... only it's not. Only for the differential.
So the only way to fill the A/T is thru the dipstick tube?
This will be my first time changing A/T fluid come to think of it... I've been working on my own cars about 7 years but I've never owned an A/T! lol.
_TIM
Old 05-05-2007, 09:38 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Yes, that is correct, you fill the transmission through the dipstick tube.
2007 Camry 2.4L 5M
Old 05-05-2007, 09:43 PM   #5 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
It;s a bitch, go buy a funnel. thats the easiest way.
5 Lug Corolla WHAT?
Old 05-06-2007, 11:11 AM   #6 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
it doesnt take too long. its through the dipstick. Some of the tranny's do have a separate plug on the side of the pan to fill or to check levels, but being horizontally positioned, doesnt help with the fill process unless you have a transmission flushing machine.
nodrogkam is offline   Reply With Quote
Old 05-07-2007, 03:00 AM   #7 (permalink)
Heat's Avatar
View Heat's Photo Gallery
Through the AT check tube, and when you buy the fluid, pick up a funnel. They sell funnels specially designed to fit, they only cost $2 or so.
Heat is offline   Reply With Quote
Old 05-08-2007, 10:43 PM   #8 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Be careful filling it up, it tends to overflow....fill it slow....or else get some rags...you will be wiping spilled cherry fluid.
mandyfig is offline   Reply With Quote
Old 05-09-2007, 10:01 AM   #9 (permalink)
View Yanpapa's Photo Gallery
Speaking of filling up a differential oil, what is a best way to fill it up? I have 97 Camry 4 cylinder(automatic) and fill plug is on a side. Do I need to get a oil pump?
Thanks.
Yanpapa is offline   Reply With Quote
Old 05-09-2007, 12:39 PM   #10 (permalink)
nodrogkam's Avatar
If i remember my haynes manual, the 97 is shared trans/diff. So you just need to fill the fluid through the transmission dipstick like normal.
Old 05-09-2007, 12:44 PM   #11 (permalink)
View toyomoho's Photo Gallery
For filling the diff, get a funnel with a very long flexible snout.
Old 05-09-2007, 08:47 PM   #12 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
And when you're getting close, give it time to drain down before checking or you'll think it's full before it is.
Dave's is offline   Reply With Quote
Old 05-10-2007, 02:05 AM   #13 (permalink)
I attached a barb fitting and a piece of 3/8" ID PVC hose to a funnel and ran the hose down to the diff fill hole from the top of the engine bay.
2007 Camry 2.4L 5M
Manual transmission oil Q IvanHoe 1st & 2nd Generation (1983–1986 & 1987-1991) 8 11-19-2006 10:40 AM
Oil in Manual transmission question IvanHoe Camry & Solara Lounge 8 11-17-2006 10:04 AM
Quick Oil Change Question usadaytrader 2nd Generation (2005+) 5 02-20-2006 09:33 AM
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 04:32 AM
