Manual tranny problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2007, 12:35 AM   #1 (permalink)
View B Dot's Photo Gallery
3rd Generation Manual tranny problems
I have a 95 Camry I4 5spd with a new clutch thats about a week old. After putting in the new clutch I noticed I have a lot of free play in 1st, 2nd and 5th gears. Today when I was driving the car it would not go into reverse does anyone know what the problem might be?
B Dot is offline   Reply With Quote
Old 05-06-2007, 01:20 AM   #2 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Did you try going forward in 1st a little then trying again or even going into first gear then shift to reverse, usually does the trick
MIC0417 is offline   Reply With Quote
Old 05-06-2007, 08:43 AM   #3 (permalink)
Yea I know that trick but it just wouldnt go into reverse at all.
Old 05-06-2007, 10:14 PM   #4 (permalink)
View marc780's Photo Gallery
Have you owned this car since new or is it used? Maybe the previous owner adjusted the clutch cable as the clutch wore, and then sold it to you like this. And now the new clutch is in and there is too much slack in the cable adjustment ( if cable and not hydraulic). And so when you push the pedal, maybe the pressure plate cant go far enough out from the flywheel (pedal not pulling pressure plate out far enough) and disc and makes it hard to shift?
New clutch or no new clutch, if anything it oughta shift the exact same or BETTEr than before the new clutch and not worse! If you had it done at a shop, i bet the sloppy mechanic did not even test drive it.
Try adjusting the clutch yourself, it is not too hard. BUT remember the trick is:
You must leave at least an inch or two of slack at the pedal. The factory manual says how much slack. This is important Because - If the clutch adjustment is too far and too tight, then the pressure plate will be held away from the disc and flywheel a little bit, even when the clutch is out. So this will cause the clutch to wear out fast and that you surely do not want.
If you had it done, take it back and try to get them to adjust it for you. If you did it yourself, check the Camry manuals for the detail info -
http://oregonstate.edu/~tongt/camry/
Old 05-06-2007, 10:35 PM   #5 (permalink)
Yea I bought it used, but there was a problem in cable or something but its fixed now and is shifting great thanx for the help.
Auto tranny question from a manual owner demoncleaner 2nd Generation (2005+) 3 11-09-2006 03:00 PM
Manual tranny build up diengcamry 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-18-2006 09:52 PM
Drop a manual tranny in an auto? Brake Weight 1st Generation (1995.5–2004) 13 07-06-2006 03:23 PM
signs of tranny problems bowlofturtle Camry & Solara Lounge 1 04-10-2005 01:02 AM
3s-ge manual tranny white90dx Celica Forum 2 10-04-2002 05:38 PM
