Control Panel Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2007, 08:45 PM   #1 (permalink)
View itchibahn's Photo Gallery
Need help removing the front control panel on Camry 1994, 2 door, 4cy. My vent control knob fell inward, and seems I need to remove the panel to get to it. Is there a document/diagram online on how to remove the front panel? I'm assuming I don't need to remove the entire dashboard.
itchibahn is offline   Reply With Quote
Old 05-06-2007, 10:56 PM   #2 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
First you take off the plastic piece that the lighter housing is in (below to the left of the radio) then just pull that out. Next you'll want to unscrew the stereo and the little cubby below it. The rest is pretty much just more screws and stuff to take off (I think) that should be it, it should not be to difficult just make sure its bright enough and everything should go smothly.
MIC0417 is offline   Reply With Quote
Old 05-07-2007, 06:41 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
The panel piece below the radio with the lighter pulls out from the bottom and is hinged at the top. Pry it out and turn it up then just pull it out. Remove radio. There are 4 screws that hold the dash panel in. Two at radio area and two at top in front of bezel. Then there are 4 clips that will release by carefully prying out the dash panel. Two on the left and two on the right. Just take it easy so you don't break anything.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Setting options in the control panel does not stay florian Site Suggestions, Questions, and Comments 0 12-23-2005 04:31 PM
Door Panel Removal bpoppe4 Camry & Solara Lounge 5 05-15-2003 09:00 PM
