I had a blown brake hose, and went to replace it, no problem, right? Well, the fitting that goes from the steel line, that connects to the rubber line, was stripped. What options are there? I can't replace the fitting itself. Can I splice into the steel line? Can I buy new lines already pre-bent?
you're right, you can't replace the hardline and it's unsafe to splice into it due to the pressure of the braking system.
but what you can try is soaking the fittings in penetrating oil to help it loosen up, and then use locking pliers to get them off....if you clamp them tight enough, it should work
otherwise, take it to a mechanic who can torch it and then clamp it
HaHa
"Life is a deep sleep, of which love is the dream..." Ripped...and the girls are loving it.
I remember some brake line fittings that were an absolute B***H to get the threaded part started, so its hard to say without being there that you need to keep trying or not.
In any event, you shouldn't have any problems replacing the hard line, unless the junkyard gives it to you pre-stripped.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
The line I got was the proper line, but I think it was to a newer model camry. Anyways, it was easy to bend to fit in the right place, as the brake like from the junkyard was longer than the original. It is in place and worked like a charm! It only cost $15, not $20.
I've never messed with my hard lines before....where does the hard line at the brakes connect to the rest of the braking system? right under the chassis?
HaHa
The top part connects to the master cylinder and the bottome fitting, which goes through the wheel well, connects to the soft brake hose right above the axel.
