vibration in rear over 60mph
in my 92 SE, i'm getting a pretty annoying vibration at 60mph and above and its source seems to be the right rear of the vehicle. i have inspected the tires for inflation and balance as well as for flat spots. i have replaced the right rear wheel bearing and have inspected the rear lateral links for wear and i see no evidence of play. what i can do is while the car is on the ground, if i grab the right rear tire, i can wiggle it. while squatting and wiggling, if i push in with my right hand and pull out with my left, the tire will move inward where i'm pushing with my right hand and makes a small clunking noise when i do so. like i said above, i inspected the links and they SEEMED ok. when i had the wheel off, i observed no play at all. i'm out of ideas. any help or suggestions would be greatly appreciated.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
