egr ?'s - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2007, 08:59 AM   #1 (permalink)
FROM V6 TO 4BANGER :(
playmategirl's Avatar
View playmategirl's Photo Gallery
3rd Generation egr ?'s
i have an engine code it says egr flow insufficient...... im guessing in short i need a new egr. my ? is can i get egr block off plates for my 1mz ? if so will i gain anything from this at all? or will i suffer? the only place to get one is toyota. or can i just clean mine and see if that helps?
YES its fast.....NO you cant drive it!
My 95 Pink and Black 1MZ Camry.... Needs a new head...currently out of commission....
My new Camry...95 5SFE...Gold and Black...for now!!
playmategirl is offline   Reply With Quote
Old 05-08-2007, 09:11 AM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Have you tried cleaning the EGR valve? Sometimes I heard it just gets clogged up with carbon build up that it may throw a code.
geoff5093 is offline   Reply With Quote
Old 05-08-2007, 09:29 AM   #3 (permalink)
ill try it and see.
Old 05-08-2007, 09:29 AM   #4 (permalink)
ill try it
Old 05-08-2007, 10:21 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
what are the emissions standards there in NC? i could just remove the whole thing and get a little power from it.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-08-2007, 11:02 AM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
yup, you can always cap it off....and then use a resistor to trick the ecu about the egr temp
but also know that you won't be able to pass your emissions without it
HaHa
Old 05-08-2007, 11:18 AM   #7 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
i got that same code, havent cleaned my egr since i cant get it off, im learning to live with the code until i have enough money to purchase a new valve.
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 05-08-2007, 11:27 AM   #8 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
You won't gain anything but you will emit more pollution for the rest of us. Just clean it. You will need to use some PB Blaster or like on nut overnight and maybe a crows foot wrench to turn it off if there is an access problem.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-08-2007, 11:45 AM   #9 (permalink)
geoff5093's Avatar
You might gain a little power, such as Eye8 said. All the EGR basically does is recycle the exhaust gas, so if you remove it, then you are letting more fresh air into the combustion chambers rather then used exhaust gases.
Old 05-08-2007, 12:01 PM   #10 (permalink)
ok thx ill see what i can do with it.
Old 05-09-2007, 05:59 AM   #11 (permalink)
Excuse me? EGR gases lower combustion temps and lower the production of N0x, a serious contributor to pollution. The EGR is shut off at idle and at WOT so you don't loose power. It is active at cruising speeds. Got dyno tests that show any significant power gains without EGR?
Old 05-09-2007, 08:20 AM   #12 (permalink)
geoff5093's Avatar
I dont have dyno tests, but i've heard from people that have gotten rid of it that they feel more low-end power, but I guess without proof then you wont believe it
Old 05-09-2007, 10:41 AM   #13 (permalink)
I HAS BOOST!!!
bigbird's Avatar
well u shouldnt do it to gain power, there isnt really enough to free up. the car will pollute more and i may ware out the cat slightly faster as well. but if u want to save money by removing somthing instead of spending money to replace it and you state will "allow" it then its an option. quite a few people here have done it and reported small power gains and no ill effects with performance anywhere in the rpm range. the choice is yours.
R.I.P.
Car Domain:
Old 05-09-2007, 01:28 PM   #14 (permalink)
The Butt Dyno is quite subjective and wants to feel more power. It is unreliable especially when little to no gain is the reality. But I guess science has no place when perception is the goal.
Old 05-09-2007, 02:09 PM   #15 (permalink)
if i do it it wouldnt be for power gains. it would be just to fix the bogging down prob and that stupid engine light.
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
2VZ-FE EGR Valve ?'s monito 1st & 2nd Generation (1983–1986 & 1987-1991) 7 01-28-2007 09:49 PM
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
1990 Camry 3sfe EGR valve Kep 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-29-2005 10:33 AM
