1995 camry coolant gauge not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2007, 03:07 PM   #1 (permalink)
View fdominguez76's Photo Gallery
USA 1995 camry coolant gauge not working
i have a 95 camry v6 1mzfe engine, my coolant gauge doesnt work. i changed the t-stat, and the sensor on the left side of the engine. i also unplugged the sensor by the t-stat when i unplugged it the fans kicked on so that tell me it is working why doesnt my gauge work. i also disassembled my dash and checked the gauge it seemed fine, i am stumbled. help please.
fdominguez76 is offline   Reply With Quote
Old 05-09-2007, 06:22 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I'm not sure you have located the gauge sending unit. It will have a single wire to it. If the gauge is inoperative and you disconnect the wire to the sending unit and ground it, the gauge should go to full hot. If it does, replace the sending unit.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-09-2007, 01:25 PM   #3 (permalink)
dsm = desert sand mica.
View 94dsm's Photo Gallery
my coolant gauge works, but rarely, like itll flicker on and off,
is the sending unit a box near the sensor?
i have a 5sfe
catbacked. miles keep pileing up quickkk!
94dsm is offline   Reply With Quote
Old 05-09-2007, 01:33 PM   #4 (permalink)
Not sure of your year but mine is located on the outlet manifold of the cooling system, where the upper rad hose is connected. There are 3 sensors there. The one with the single wire is it. Yours sounds like loose/bad connection at plug.
Old 05-09-2007, 01:39 PM   #5 (permalink)
View toyomoho's Photo Gallery
Download the Gen_3 service manual and cooling system info from the link below:
http://oregonstate.edu/~tongt/camry
Old 05-09-2007, 01:47 PM   #6 (permalink)
yes mine is a 94, and last year when i was replacing the distributor i broke off the top of the middle one, (of the three sensors), and it ran like crap and was hard as hell to start the car. but i replaced it, with a used one. but im gonna go out and check it out now
Old 05-09-2007, 03:14 PM   #7 (permalink)
Now I don't know if there are two sensor with a single wire on that manifold. The one you describe sounds like a cold start temp sensor. Car not here to check. I'm pretty sure gauge sender only controls gauge, not ECM rich/lean for cold starts. Check download manual as toyomoho says.
Old 05-09-2007, 05:27 PM   #8 (permalink)
Thanks guys i will check it out
Old 05-10-2007, 12:27 AM   #9 (permalink)
yea i took another look at it and it was the green one that controled the cold startup.
the middle one is the one with one wire. and it didnt do anything when i grounded either of them. so ill pick one up on friday.along with a tstat and some new coolant
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Need Help On Camry Inverter Gauge? tooyoungtoodie General Discussion 1 03-13-2005 01:16 AM
1995 Toyota Camry LE /w ABS jj2ii3344 3rd & 4th Generation (1992–1996 & 1997–2001) 1 05-29-2004 11:03 PM
