Originally Posted by Stillrunning
On your 93, was it possible to replace the coil without replacing the distributor?
Sorry, i'm not sure. I got a good price on rebuilt distrubutor and I just popped it back in. I would just replace the whole assembly.
Update: I'm out of school now so I have a little more time between work hours. I replaced the ignitor coil because it went bad and also replaced my spark plug wires because one of the tips broke off into the ignitor which probably caused it to go bad in the first place.
The car still won't start. camshaft sensor, crankshaft sensor, wires, ignitors, fuel delivery is all fine. I'm still not getting any spark though. If my timing happened to jump a tooth or more, would this cause the no spark issue? I'm guessing not but maybe.
Also I tried to read the voltage on my ecm for terminal E7-1 which should always have constant voltage even when the car is off but I'm not reading anything. So i need some suggestions.
edit: forgot to add that all fuses are ok unless i'm missing something
thanks for your time guys
