Some tiny problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2007, 04:16 PM   #1 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
Some tiny problem
I washed and detailed today, however this is problem I have has been bothering me. It doens't really do anything but it wrecks the appearance.
My spray nozzles on the hood, the right one is constant leaking out windshield fluid. There are dried fluid marks on the hood all the time even if I don't use the fluids. Been pissing me off cause it leaves the dried marks on the hood.
EvoFire is offline   Reply With Quote
Old 05-10-2007, 05:12 PM   #2 (permalink)
toyocam99's Avatar
Gameroom cash: $118835
View toyocam99's Photo Gallery
go to a toyota dealership and buy a new, they're like $15 or something around there.
toyocam99 is offline   Reply With Quote
Old 05-10-2007, 05:31 PM   #3 (permalink)
EvoFire's Avatar
that doesn't explain it though.... and you didn't say which part to get....
Old 05-11-2007, 05:30 AM   #4 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Yes it does, if its leaking just get the new sprayer pull the hose out of the old broken one and put the new one in and attatch the hose to it.
MIC0417 is offline   Reply With Quote
Old 05-11-2007, 10:21 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
its most likely the the rubber tube feeding the nozzle has cracked. all the heat under the hood eventually dries it out ant it prolly cracked where it connects to the nozzle. just replace that piece and then it wont leak.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-12-2007, 01:13 AM   #6 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Get a sewing needle, and stick it in the 2 holes, on each sprayer. There is a calcium deposit. You'll see the white crude. That usually does the trick. GL.
5 Lug Corolla WHAT?
Old 05-12-2007, 01:25 PM   #7 (permalink)
EvoFire's Avatar
ok, thanks.
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
vacuum sucks! 1995 4afe problem madalo Archived Corolla threads 4 02-08-2004 01:49 AM
