Idle - slow and surging ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2007, 05:31 PM   #1 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
My idle is a bit slow and surging ...
Any ideas ?
2000 4cyl
thx
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
Old 05-10-2007, 06:11 PM   #2 (permalink)
View popeye08's Photo Gallery
ECT(engine coolant temperature) sensor problem
popeye08 is offline   Reply With Quote
Old 05-11-2007, 11:53 AM   #3 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Do you mean hesitant, weak idle, that can be fixed by cleaning the TB and a new air filter.
MIC0417 is offline   Reply With Quote
Old 05-11-2007, 06:52 PM   #4 (permalink)
alotawatts's Avatar
No ...... it's just that the rpms are not steady........
Old 05-11-2007, 10:27 PM   #5 (permalink)
View toyomoho's Photo Gallery
Look at the IAC valve and MAP sensor.
Old 05-12-2007, 04:45 PM   #6 (permalink)
Gameroom cash: $303055
Check carefully for vacuum leaks. Also check the large tube leading to the throttle body for leaks and cracks. Unmetered air entering through cracks there can cause an unstable idle.
Mike
Old 05-12-2007, 09:32 PM   #7 (permalink)
At first find wherer the sensor connector is on the engine, you can download the manual to find it. When the engine is surge, just pull out the plug to disconnect the sensor, if stable, you must have a bad ECT sensor. About $40 in Autozone.
It probably has a dirty IAC valve as well, so the idle is low. Just search in this forum and clean it
