gas mileage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2007, 02:18 AM   #1 (permalink)
View evoicon06's Photo Gallery
XXX gas mileage
hey everyone im new to this...i have a few questions....i have a 98 v6....and i get very poor gas mileage....a few weeks ago i was getting around 18-19mpg....but now it has gone down to about 15-16mpg...my driving style has been the same...im curious to know if ac can really affect it that much....and what can i do to improve gas mileage?...change fuel filter?...differant gas?...what can i do?....help me out guys...any help will be apreciated
evoicon06 is offline   Reply With Quote
Old 05-11-2007, 06:26 AM   #2 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Could be it is need of maintenance, Fuel filter, new spark plugs, new oil/fluids and yes depending on the A/C you can use a lot, also air filter and clean the throttle body, it's an old V6 so don't expect great MGP but that is wierd, probably just needs some good ol'routine maintenance.
MIC0417 is offline   Reply With Quote
Old 05-11-2007, 11:25 AM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
it shouldnt be that bad. even with A/C i can still get at least around 22mpg. when was the car last serviced? any performance loss?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
bigbird is online now   Reply With Quote
Old 05-11-2007, 02:28 PM   #4 (permalink)
4th Generation
thanks...i bought the car last year...and im not sure if it was well maintained so i want to probly change a lot of stuff.......fuel filter(problem is that i dont know what exactly to do)....sparkplugs(do you guys recommend anything)....fuids( i dont know exactly which ones or how often to change them)...i change the oil every 3000-3500 but thats about it....last week i used shell and the car felt a lot better and now im back to valero and it feels slow...any information will help.
Old 05-11-2007, 09:19 PM   #5 (permalink)
View jatan1986's Photo Gallery
Tune up (plugs, PCV valve, air & fuel filters, clean throttle body), tire pressure (make sure its all even) and front oxygen sensors. O2 sensors control your air/fuel ratio and when they get old, their response gets slow which causes lower MPG (on my Maxima, I went from 15-17mpg range to 18-21mpg range after changing my front O2 sensors and my mom's 4cyl Camry went up by 3mpg after changing the front O2 sensor)
NGK V-Power copper plugs are good
jatan1986 is offline   Reply With Quote
Old 09-05-2007, 07:49 PM   #6 (permalink)
View mitsubishi_powe's Photo Gallery
I Get 15MPG in my V6 camry 97
Check my car here
http://www.cardomain.com/ride/1199111
1/4 mile time 15.6 @ 87.2 MPH
1/8 mile time 9.988 @ 71MPH
mitsubishi_powe is offline   Reply With Quote
Old 09-05-2007, 07:56 PM   #7 (permalink)
'95 Camry 5S-FE
Gameroom cash: $251167
View 95PimpingCamry's Photo Gallery
I personally have a '95 4 banger, but I saw a jump in my gas milage when I replaced my spark plugs(NGK Iridium IX), spark plug wires (NGK), distributor cap/rotor(Denso), and ingnition coil(Denso). Also insure that you have a clean air filter and fuel filter. And as everyone already knows, the biggest way to save gas is to lay off the gas pedal.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Bad Gas Mileage jkgecko 1st Generation (2003-2008) 36 01-12-2009 07:21 AM
more gas mileage, how much acetone do u add to gas. Question umeshr85 3rd & 4th Generation (1992–1996 & 1997–2001) 16 06-30-2008 11:44 PM
6cyl vs 4cyl in gas mileage Jaccer11 1st Generation (1995.5–2004) 18 04-23-2007 04:15 PM
gas mileage Austinrd 1st Generation (1995.5–2004) 7 01-24-2007 05:16 PM
Your Gas Mileage?! acrylucs 1st Generation (2003-2008) 25 07-22-2005 04:14 PM
