you normally would just stick the 5s-fe crank in a 3s-gte block, but whatever you want lol! I'd change the pistons & rods out since you're already un-mating the head. Which is seirously beginning to get into "Just buy a 2s-gte and put your crank in it" territory.
You're also in the price range of swapping your pistons, rods & porting & piolishing your FE head (use an MLS gasket).That would probably produce the msot power for the least money by far.
I see 0 reason to use a 3s-gte head unless it's just free. even a mild hand porting job will eclipse what the gte head would flow without the same treatement.
AIM/Yahoo Toysrme257th
Now with Turbo!
