Hey thank you all for trying to help me get down to the bottom of this.
I had my tires replaced and the guy said its my front bearings going wrong.
Then I went out with a friend one day, and he told me its the rear right bearing.
I replaced that and the noise got better, but was still there.
Finally, the guy who put the bearing into the hub for me said its the rear left.
I replaced that, and my two months agony was fixed.
It was difficult to pinpoint where the humming was coming from.
Sitting in the rear I could hear the other rotating sound (indication of the bad bearing), but I could not figure out the humming.
Coincidentally, the sounds started right after I finished my timing belt/water pump change.
BTW for those of you who do your own work, the rear bearings do not need to be replaced with the hub assembly. I know the manuals said so, but mine was pulled out, and pressed in successfully, and now my car drives great. Very easy DIY.
Unfortunately, I had an allignment done, and Firestone told me both my front inner tie rod ends are getting bad. Thats the next project....
